Question about Fluke 705 Process Calibrator,current And Voltage
Fluke 705 loop calibrator fuse blown
Hello. I have a blown fuse and relay on my fluke 705. Does someone can tell me the reference of this fuse and relay? F1 and U11 on the pcb. Thank you. http://img687.imageshack.us/img687/6969/26102012893.jpg http://img59.imageshack.us/img59/7417/26102012894.jpg
  • brunopere526
    brunopere526 May 12, 2013
    Thank you Vuk B. My 705 is "alive" again with an NEC EA2-5T relay, it was hard to find, and for now, an 200mA fuse!! This is a rev. C MARTEL ELECTRONICS board, and now i found that i also need to replace D11, D10 and D1. I think that these are 2.2v zeners, i will give it a try.
    Master:
  • 683 Answers
Hello Bruno:
F1 (Fluke PN:800901 Ver. A,B and C) (PN: 1778294 Ver. D & E) is 350mA 600V fuse.
U11 (Fluke PN:687555) is DPDT Latching 5 Volt Coil
I would also check D12 if your revision has one (PN:1617521) which is sidactor and it's other side of the board (DO-214 58V).
Good luck.
Posted on Oct 29, 2012
benleves
  • 92 Answers
SOURCE: fluke 97 scopemeter will not power up
i have the same problem now check in your fluke you have a fusse change it
Posted on Dec 03, 2008
VtToolMan
  • 704 Answers
SOURCE: WHEN I TURN ON MY FLUKE 179 IT READS ERROR AND
Hi, that is the error message indicating a EEPROM error and unfortunatlely, you can't do anything except have the meter serviced by either Fluke directly, or by an authorized Fluke test equipment dealer.
Since Fluke doesn't provide the specs and coding for their products, you wouldn't be able to repair the meter properly, even if you could burn and program your own chipset.
Here's a copy of the manual for your meter, so you can contact Fluke for servicing and see the other info relating to it (for your future reference)
http://assets.fluke.com/manuals/175_____umeng0100.pdf
Sorry to be the bearer of bad news, but Fluke products are typically quality test instruments and there might be a possibility that you're still covered under their warranty, so checking with them is the best avenue for getting it back to working condition.
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
  • 4234 Answers
SOURCE: Fluke 1651portable multifunction tester is displays Err 1
Error 1 is an indication that the self test has failed. This will require repair at an authorized Fluke service center. There is an internal problem with the meter. The only thing that you can try is to replace the internal battery. Should the battery be defective, the internal testing can be effected. I have only seen this occur once, but it is worth the attempt. Should a new battery not fix the problem, return the meter to Fluke for repair.
Dan
Posted on Apr 15, 2010
  • 8404 Answers
SOURCE: I looking for fluke 179 service manual
Go take a look here please: http://www.fluke.com/fluke/usen/support/default.htm I found your manual here: http://www.fluke.com/Fluke/usen/support/manuals/default.htme: but you may not be able to go to this directly. Click on the Manuals tab then search your model number.
I trust this is what you are looking for.
Thanks for your interest in FixYa.com
Posted on Feb 14, 2011
  • 683 Answers
SOURCE: where would i find the serial number for the fluke
Inside battery compartment.
Posted on Aug 31, 2011
Looking for the fuse for the wiper motor 2008 chevy impala
WPR fuse 25amp under hood fuse box .
Wiper/Washer System Components
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper PCB relay
• Wiper high PCB relay
• Windshield wiper motor
• Windshield washer fluid pump
• Windshield washer fluid level switch
• WPR fuse 25 A
• WSW fuse 10 A
This is more then likely not a fuse issue !!!!!!!
Low Speed Operation
When the wiper switch is in the low speed position, ground is applied through the switch internal resistor and the wiper switch low signal circuit to the body control module (BCM). In response to this signal, the BCM energizes the WIPER PCB relay by applying battery voltage through the wiper relay control circuit to the coil side of the relay. This allows battery positive voltage from the WPR fuse to flow through the switch input side of the WIPER PCB relay and out to the switch input side of the WIPER HIGH PCB relay. Since the wiper high relay is de-energized and its switch contacts are normally closed to the low speed control circuit of the windshield wiper motor, the motor will operate at low speed.
Wiper motor low speed operation and the wiper PCB relay can also be commanded ON/OFF by using a scan tool. Refer to Control Module References.
The PCB relays mentioned above are soldered right into the circuit board inside the fuse/relay block under the hood . There are alot of reasons for the wipers not to work ! The fuse could be blown but fuse's don't just blow for no good reason , short to ground , low resistance high current flow etc.... Intermittant !
Power and Grounds
With the ignition in the ON position, accessory voltage is supplied through the 25A WPR fuse to the WIPER PCB relay, the WIPER HIGH PCB relay and the WS WASH PCB relay that are all located in the underhood fuse block. Refer to Wiper/Washer Schematics.
G200 provides ground for the windshield wiper motor and the WIPER PCB relay. G100 provides ground for the windshield washer fluid pump and the windshield washer fluid level switch.
Dec 04, 2016 | Cars & Trucks
I'm driving in rain, wipers working good, all of a sudden they quit! I drive for 15 min, check again, they work for a while, then quit again...what in the problem?
If your not familiar with automotive electronics an module control of components , I suggest you take it to the dealer . They have the tools to diagnose this type problem !
Wiper PCB relay
WPR fuse 25 A
WSW fuse 10 A
Low Speed Operation
High Speed Operation When the wiper switch is in the high speed position, ground is applied through the windshield wiper switch high signal circuit to the body control module (BCM) indicating the wiper high speed request. In response to this signal, the BCM then energizes the wiper PCB relay, as stated above, and the wiper high PCB relay by applying ground through the control circuit to the coil side of the relay. With the wiper high relay energized and its switch contacts closed to the high speed control circuit of the wiper motor, the motor will operate at high speed.
Wiper motor high speed operation and the wiper high speed PCB relay can also be commanded ON/OFF by using a scan tool. Refer to Control Module References.
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
DTC B3875 00: Wiper High Speed Relay Circuit
DTC B3922 00: Front Wiper Function Select Circuit
You could Have a switch problem , BCM problem ,PCB relay problem , the pcb relays are non serviceable an the whole under hood fuse box would need to be replaced . Malfunctioning motor bad ground some where etc.....
Dec 20, 2015 | 2008 Chevrolet Impala
2008 Chevy Impala LTZ: car wont lock or unlock with the power lock/unlock buttons on the remote or car door. It makes a clicking sound though when I attempt to. Is this a blown fuse? Or something else
Where do you here the clicking sound ? in the door , behind instrument panel ? I don't think a blown fuse would do this , possibly a relay ! do you know what a relay is ? This is Chevy factory service information !
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
There are three pcb relays integrated into the instrument panel fuse box ( non replaceable ) door unlock pcb relay drivers door -door unlock pcb relay an door lock pcb relay ! The BCM controls these relays ! Do you know what a BCM is ?
Circuit/System Description
The DR/LCK fuse supplies battery positive voltage to the I/P fuse block for the door lock system. The body control module (BCM) supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position or unlock position, the reference voltage is taken directly to ground and the BCM detects the voltage drop on the signal circuit.
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
With out have a factory GM tech 2 scan tool ,It would be best if you took this to a Chevy dealer . The first part of diagnosing this problem is to hook up a scan tool !
Wiht
There
How to test computer controlled door locks
Aug 25, 2015 | Cars & Trucks
Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Mar 09, 2010 | Athena AS-P4000 Subwoofer
Car overheating
This relay you are referring to should be in the engine compartment electrical box this is also known as the distribution box normaaly houses relays and high current fuses
Sep 20, 2009 | 2006 Dodge Magnum
Model #AJ6111-37. Serial #lm100728050845. I have
Is the unit under warranty? If not problably a fuse. take unit a part. main power pcb located on left side towars rear. remove scews holding it and have a look there. these are typically pico fuses labeled f1...f2 etc. Check for continuity with a meter if blown it will say OL if ok should read 0. Fuses and are available at your local electronic store.
Hope this is helpful.
Jun 24, 2009 | Philips Under-Cabinet Alarm Clock Radio...
Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
May 31, 2009 | Heating & Cooling
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
RSD30 F1 Error Code
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection. why would he replace the spark module?if the door is not closing>>> are the burners not igniting?
Bezel Panel
76480b/r BEZEL (Almond/Black/Arctic)
Spark Module
86526 SPARK MODULE, 4 POINT,
Both door hinges
82883 HINGE, DOOR
* 82508 HINGE, DOOR (Stainless Front)
or to fix your F1 error
Aug 01, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Oven Failure Code F1
Nov 20, 2007 | Dacor Preference RSD30 Gas Kitchen Range
Fluke 705 Process Calibrator,current And Voltage Logo
638 people viewed this question
Top Fluke Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Fluke Measuring Tool and Sensor Expert? Answer questions, earn points and help others
