Question about Kitchen Ranges
How do I change a light bulb in a Baumatic bah9008g range hood
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
zeusfaber
  • 247 Answers
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Posted on Apr 05, 2008
  • 171 Answers
SOURCE: range hood light failure
Hi bentson,
I'm Harvey the Master Plumber.
Your problem is: Fan works but lights will not. switched bulbs and still lights not working.
You are dealing with a bad light switch. If you have the tools and the talent go for it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
Treefrog15
  • 127 Answers
SOURCE: put new bulb in baumatic kichen hood turned it on,
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Posted on Feb 25, 2010
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
Apr 18, 2014 | Zephyr Kitchen Ranges
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
Put new bulb in baumatic kichen hood turned it on, instantly made a noise like it tripped out, fan and lights now don't work, can not find fuse?
Feb 24, 2010 | Baumatic F60 Stainless Steel Kitchen Hood
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Nov 17, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
Baumatic cooker hood lights not working
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Mar 02, 2007 | Baumatic F60 Stainless Steel Kitchen Hood
Kitchen Ranges Logo
106 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
