Question about Sachtler Video 18 P Carbon Fiber Complete Tripod System 18p
Can anyone service/repairSACHTLER VIDEO 18P - TRIPOD
HEAD REQUIRES FULL SERVICE: UNIT SHOWS SIGNS OF SAND INGRESS 1.TOP PLATE HAS ROUGH MOTION BENT LOCKING AXLE, RUSTED WASHER 2.BENT TILT BRAKE AXLE AND MISSING WASHER 3.WORN TILT BRAKE HOLDER HAS SLIGHT MOVEMENT 4.WORN TILT SELECTOR RING 5.COUNTER BALANCE SELECTOR HAS SAND INGRESS 6.MISSING SIDE COVER 7.BATTERY COMPARTMENT SHOWS SIGNS OF SAND INGRESS [PAN SERVICE] LEGS REQUIRE FULL SERVICE: UNIT HAS SAND INGRESS BRAKES AND SLIDING COLLARS 1.FULL STRIP CLEAN AND RE-GREASE 2.BOWL BOLTS CORRODED 3.SEIZED SPREADER LOCKING LUGS 4.CLEAN SPREADER **PLUS ANY PARTS FOUND TO BE FAULTY OR DAMAGED ONCE FULLY DISMANTLED**
3 Suggested Answers
  • 15 Answers
SOURCE: Sachtler 18 tripod has no lock tilt
Visual impact can supply parts.
Posted on Jan 08, 2009
SOURCE: I have a Sachtler Video 18P Fluid Head. I know
Just press hard on the bubble with your finger to turn the bubble light on. You may have to do it a couple of times. It goes off by itself after a short time.
Posted on Jun 22, 2011
Top thread breaking while doing free motion quilting. Changed needle, rethreaded machine and bobbin.
ck your bobbin plate alignment if it got bent while free handing and needle came down and bent/broke then theres a good chance its out of alignment this usually requires replacement to repair this
Feb 29, 2016 | Sewing Machines
How can I mount rc498c4 on my bogen 3001 tripod legs
Go to http://www.bogentripodparts.com/repairs.htm and the top right video shows how to remove and replace the head.
Mar 28, 2013 | Bogen Manfrotto 498rc4 Midi Ball Head W/rc...
Need to replace the ravelli quick release plate for ballhead tripod
Here is the complete unit replacement:
http://www.amazon.com/Ravelli-Professional-65-inch-Carbon-Release/dp/B004RCHX0W
No parts lists are available on line for this tripod.
Jan 14, 2013 | Ravelli Professional 65" Ball Head Camera...
Giottos MT-8170 center top plate 3/8" screw broken, can the screw or plate be replaced?
You unfortunately can replace the screw; however you can find a new plate at www.tripodquickrelease.com. They carry Giotto quick releases.
Dec 25, 2012 | Giottos Photography
Slight dent in one leg near base plate,how does the top section come away from base plate for possible repair,leg will not close all the way.
Check out : www.bogentripodparts.com. While I am not that familiar with that model, there are parts available)not sure which ones_ and ther is a video on tripod repair, albeit a different model.
Apr 24, 2011 | Manfrotto (Distributed by Bogen) 055XDB...
I have a Sachtler Video 18P Fluid Head. I know where the batteries are for the balance bubble, but I can't figure out how to turn the bubble light on. The tripod is fairly new, so I'm not sure if the...
Mar 25, 2011 | Sachtler Video 25 Plus Fluid Head (150mm...
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
It is constantly loose will turn easily without depressing the handle! Ive had it for a few years now and it started doing it this year. I use it with a tripod mounted Leica Spotting scope and it has been...
The normal tightness adjustment is black and on both sides of the handle. There is a plus and minus sign above it on the left side of the grip to show how to get more and less tightness.
There is a SECOND adjustment that I just found on the back side of the handle (opposite side from the gray grip on the front). This one requires a very small allen wrench to tighten (clockwise). I assume that this one was designed as the rough adjustment and the upper one is supposed to be for fine tuning during a photo shoot or normal use.
Either way, I'm glad I don't have to replace my tripod head. She's been halfway across the world with me!
Nov 01, 2009 | Bogen Communication Bogen Manfrotto 3265...
How to remove pan head from velbon 530, it feels very tight
I have the Hakuba HG-503MX which came with basically the same pan head you have already attached to the center column. First remove the center column from the tripod, with the pan head attached. Tighten the knob that prevents the pan head unit from rotating 360 degrees on the center column and gripping the head with one a hand and the center column near the plastic plate firmly twisting the head counter clockwise. The pan head will unscrew from the plastic plate which sits on top of the center column, given enough force. My pan head was also very tightly screwed onto the shaft, since it came already attached to the tripod. Hope this is helpful.
Aug 10, 2009 | Velbon EL Carmagne 530 Tripod
Sachtler Video 18 P Carbon Fiber Complete Tripod System 18p Logo
780 people viewed this question
Top Sachtler Photography Experts
Tom Chichester
Tony Parsons
Tony Parsons
Neha Kaur
Neha Kaur
Are you a Sachtler Photography Expert? Answer questions, earn points and help others
