Question about Lexmark X2690 All-In-One InkJet Printer
Lexmark X2690 all in one does not print colors properly
When I try to print colors the reds come out yellow and there are other color shifts.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Should "cleaning the print nozzles" do anything with the color cartridge?
First, make sure the cartridge isn't dry. You may have to get into the Printer Preferences and check to see if the software hasn't been changed to 'black only'.
Feb 08, 2012 | Lexmark X2690 All-In-One InkJet Printer
My Lexmark printer X2690 will not align properly after I' ve installed a new colour cartridge I have taken the security strip off! please help
You could try to remove and reinstall your color cartridge again.Do a Clean Cartridges cycle.Then do an Align Cartridges cycle.
Oct 26, 2011 | Lexmark X2690 All-In-One InkJet Printer
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
NOT PRINTING COLOR (INK LEVEL GOOD) PRINTS ON BLK/WHITE MODE
Your color cartridge may need some cleaning. If you're using Windows, go to Start menu > Prorgrams/All Programs > Lexmark 2600 Series > Solution Center. Go to Maintenance tab and select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If problem continues, try to insert a different known working color cartridge to determine if it's a faulty cartridge issue.
Jul 29, 2011 | Lexmark X2690 All-In-One InkJet Printer
The Lexmark Z645 will only print blue, yellow and black
Hello. The nozzles of the color cartridge may need cleaning since it's doing the same thing on two different printers. Here's an article in the Lexmark website on how to properly clean the nozzles of the cartridge. Just click on this link: http://bit.ly/9wzuAL . If it still won't work, try your old color cartridge if you still have it and still working. If it works properly with the old cartridge, maybe you got a defective new cartridge. Hope this helps. Good luck!
Mar 23, 2010 | Lexmark Z645 InkJet Photo Printer
I have installed 2 new cartridges & the black prints but the color will not.
i have only one balck cartridge in lexmark x2690 one cartridge is lost then my printer is not start the printer message is one cartridge is installed then i want a one cartridge is lexmark x2690
Jan 22, 2010 | Lexmark X2690 All-In-One InkJet Printer
The cartridsge printe red and blue fine. No yellow
The print head for the yellow color may be clogged. Check the manual to see how to turn on your print head's cleaning system. Run it until the yellow starts to print properly. If after running the cycle 4 or 5 times you still can't get any yellow to print you will probably have to take the printer to your local repair depot to have them diagnose the problem.
Jul 11, 2009 | Office Equipment & Supplies
Cartridge lexmark 15 is compatible with lexmark x2690?
No, a Lexmark # 15 is not compatible with the 2690.
The 2690 uses a #4 (Black) or #5 (Color). Also a # 4A (Black) and a #5A (Color). You can also use a #31 (Photo Print) cartridge.
Don
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
Cannot install x2600 series printer w/WMe
Your operating system is not supported by Lexmark (http://www.lexmark.com/lexmark/product/home/508/0,6970,204816596_653399443_1189433852_en,00.html?tabId=7)
You could try selected another Lexmark printer from your list of printer in WME. Start with the color ones first and then try the B/W ones. Failing that try installing some color printers from other manufacturers IBM for example.
Mar 08, 2009 | Lexmark X2690 All-In-One InkJet Printer
Open Questions:
See all Lexmark X2690 All-In-One InkJet Printer Questions
Lexmark X2690 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
