Question about Samsung TXN3071WHF 30" TV
Picture Size I Can't find the right picture size on this Samsung even if go wide panoram zoom1 zoom2 or 4:3 I can't see the bottom or top of the image. Very annoying when you watching a game can't see the score. Can somebody Help me Please
  • 2 more comments
  • dequindre Dec 10, 2007
    My TV seemed to be to zoomed in and i the picture is distorted and i cant see the full screen, i cant see the full titles and i tried to adjust my cable box but it also happens when i play video games so i dont think its my cable box, but that didnt help any way
  • Anonymous Mar 01, 2008
    my tv is also zoom in , i cant see full titles on normal channels and video games . ive lost my original remote control and have been using an univesal remote , it doesnt even have zoom buttons .so it begs the question , why is my tv zoomed and how do i fix it?
  • bobbydb1 Jun 10, 2008
    I have the same problem. My TV is a Samsung T3732H. I have DirecTV with an H20
    receiver. I have one output from the receiver going to an RCA DVR (DRC8030N),
    and the other one going to the TV. I also have an Over The Air
    antenna connected to a splitter with one side going to a Samsung DVD recorder
    (DVD R-120), and the other side going to the antenna input of the TV.
    I can route the satellite signal through the receiver
    straight to the TV (using HDMI1) or through the DVR to the TV (using component cable 1).
    I can route the OTA antenna through the DVD R-120 to the
    TV (using component cable 2) , or straight from the antenna to the TV.
    I only have the problem when the signal comes through the
    H20 satellite receiver straight to the TV, or through the DVR, and the signal being received is something besides
    1080i.
    When a 1080i signal is being received the TV automatically selects “Just
    Scan” and the picture is displayed correctly. When something else is received
    (the TV info button doesn’t always tell you what type of signal you are
    getting), that is when I have the problem. The top and bottom of the picture is
    cut off. I’ve tried 16:9, zoom 1, zoom 2, and 4:3 with the same result. It
    looks like the TV is zoomed all the time, just as described in the other
    emails.
    When I use the OTA antenna and go through the High
    Definition ATSC tuner on the TV everything is displayed correctly. When the TV
    receives a 1080i, 480i, or 720p, the correct size is automatically selected and can be checked with the info button on the remote. The size can then be changed, if for some reason you want something different.
    If the TV doesn’t have some way to change the display
    setting that does not show up in the menu, then it looks like the problem is being
    produced in the Satellite receiver.
  • keithocon35 Apr 05, 2009
    I have the same problem. Picture seems to be too zoomed in. When I try to adjust the P. Size it says "not available" on the TV. I can adjust DVR and my video games, but not the signal from the DVR.
    Novelist:
  • 192 Answers
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Posted on May 13, 2007
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
Feb 05, 2015 | TruTech PVS31170S1W 17 in. LCD Television
Picture Size
please provide the maker & the model & part # of your unit..
Thank you
May 02, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How do i ajust the picture size to fit the tv?
get the remote... go to menu...roll through to you come to picture / set up here you should see zoom1, zoom 2, normal, wide and panaramic... (note that some shows broadcast in wide screen) top & bottom is cut off...and in hi def the box (picture is showing like a box) all around is black out...don't feel bad I have 56 inch hi def and get mad.... i have 4inches all around all black out if i wanted a 48 .....
just enjoy it Season Greetings
Dec 26, 2010 | Philips 32PF5531D 32 in. LCD Television
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Cannot see words at the bottom of the screen.
i think you should call them first, time warner, i don't see any problem with your unit.you try evrything and only this time warner is the only problem.they are sending incompatible tv formats.
May 31, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Picture size to wide
I am not convinced that the tv is at fault. The answer may be in the menus of the set top box, if you are using one. If you have cable then put the cable wire directly into the TV to see if the TV is at fault or not. If you have satellite then consider calling your provider to ask if they have a zoom function setting in the box.
Mar 26, 2008 | Televison & Video
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Vizio 37'' TV
This is normal.
Oct 21, 2007 | Vizio L37 Television
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
461 people viewed this question
Jerry Greenberg
Jerry Greenberg
