Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
My Device button once pushed will shut off the TV.
After the device button is pushed the TV will shut off and then I have to unplug the TV in order to get the timer to turn off so that the television can be turned back on. Each time the TV is turned back on it will ask if the lamp has been changed. We have had the TV for about 2 weeks now, we need some help. Thanks
  • Anonymous Mar 18, 2009
    exactly the same
  • wrkit4u Mar 29, 2009
    My Device button shuts of the tv and it will not come back on. I have unplugged it for days at a time. The timer button continues to blink and resetting it does not help! Anyone with the same problem? How do you fix this?
  • 87 Answers
Mitsubishi can help with problem call 1-800-332-2119 your DM chassis has gone bad find a authorized servicer in your area. Call Mitsubishi first
Posted on Apr 12, 2009
What is the code for a GE remote
turn device on (tv etc)
hold power and device button until remote blinks
release both buttons
press power repeatedly until device shuts off
when device shuts off push device button on remote to save setting should blink again
press power test that remote operates device
Nov 10, 2016 | GE Televison & Video
Do someone have a vcr remote code for kaon ksc 570?
Turn device on (tv etc)
press power and test that remote operates device
Nov 10, 2016 | Televison & Video
I need a code for a Philips TV to be programmed to a living solutions remote # atc - 1688
  • Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  • Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  • Push the power button on the remote. This should turn on the device that you are syncing.
  • Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  • Press "OK" or "Enter" on the remote once the synced device turns off.
  • Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Apr 26, 2015 | Philips Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
How do you program an RCA "RCR 615 DCM1" universal remote? Any instructions out there?
I know this is an old post, however if anyone else needs to know how to program the RCA RCR 615 DCM1 universal remote here is how: Turn on the device you wish to program, dold the device button you wish to program (tv, vcr, dvd, etc.) While holding the button with one hand, press and hold the power button with the other, hold both buttons until the device button lights up and stays on then release both buttons at once. Light should remain on. Point remote toward the device and press play button every 5 seconds until device shuts off. Once the device shuts off, with remote still pointed toward the device, slowly hit the reverse button (rewind button) until the device turns on again and then hit stop button. Now your device should be programmed. Repeat for each device. Hope this helps someone, because I had this problem myself and I played around with the remote until I figured it out . This may work for other RCA RCR----- remotes as well.
Apr 29, 2010 | RCA Universal Remote Control
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WD-62827 shuts down after pushing the device button.
With the remote press menu 2470 enter then do a system reset after the set has reinitialized this should fix your problem, you will have to reprogram your channel settings afterwards though.
Oct 17, 2009 | Mitsubishi Televison & Video
I can't find the code for our tv brand it is a
    Try This Out
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player2.gif, VCR or stereo.
  2. Step 2 Pointthe remote at the device you are programming and press thecorresponding device button on the remote. These buttons are labeled"TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  6. Step 6 Pressthe device button for the component you just programmed, and hit thepower button while pointing the remote at the component. If programmedcorrectly, the device should turn on, and you should be able to controlit with your Living Solutions Universal Remote.
Sep 21, 2009 | Big Button TV Universal Remote
CODE FOR TDE SYSTEMS UNIVERSAL REMOTE CONTROL
CANNOT PROGRAM THE TDE SYSTEN=MS JUMBO REMOTE WITH CODES FOR A CITIZEN TV
Mar 01, 2009 | Universal Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
