Question about Ricoh Aficio AP2600 Laser Printer
ERROR SC865 RICOH AFICO MP3350 - Ricoh Aficio AP2600 Laser Printer
4 Suggested Answers
  • 86 Answers
SOURCE: Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Posted on Jan 13, 2009
  • 903 Answers
SOURCE: when my ricoh afico 1018
SC320 is a polygon mirror motor error. It could be caused by a poor connection or a faulty circuit board, but the most likely culprit is the polygon mirror motor itself. Replacing this motor (part #G0291961) is the most likely solution.
Hope that helps!
Posted on Sep 24, 2010
  • 903 Answers
SOURCE: Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Posted on Oct 10, 2010
HELP ME RESET ERROR SC829 IN MY MACHINE RICOH AFICIO MP 3350
Code: SC829 Code SC829 Description Self-diagnostic error 9: Optional RAM Causes • Change the controller board or the optional RAM DIMM Sounds like an engineer is needed!
Dec 08, 2015 | Ricoh Aficio MP3350
Solution for aficio mp 2352sp error code sc865
Address book data error,
clear ucs settings under mode option in service mode and if still error coming then format HDD,by taking backup
Feb 11, 2015 | Ricoh Aficio MP2352 Copier
How to Remove error code SC865
Hi there
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
It details the SC86? as hard disk or disk controller problems with SC865 being specifically the hard disk. I therefore doubt if you will be able to get rid of this fault without replacing at least the hard disk and possible the disk controller board as well.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 23, 2014 | Ricoh Aficio MP2352 Copier
What will I do to Ricoh Aficio MP 3350B with an error code of SC220?
Ricoh Copier Error Code SC 220 is Laser Sync Detect problem. Check your manual and there is a fix for this in the menu.
Sep 30, 2014 | Ricoh Aficio MP3350
When i copy using my ricoh aficio 3350 the machine cut the image in half, please help
Have you checked that you are 'telling' the copier to use the correct size of paper? You need to tell it that you are using eg an A5 image sheet and an A4 output sheet. The normal default is A4 for both.
Jan 07, 2014 | Ricoh Aficio MP3350
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Richo Aficio 3035 shows error SC865-01 What do I do?
the problem is with a electronic board, so nothing can be done by the used, the specific board need to be replaced.
Jan 14, 2013 | Ricoh Aficio 3045, 3035 Kit
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
When my ricoh afico 1018 printor is on error corde desplay sc320?
Hope that helps!
Sep 13, 2010 | Ricoh Aficio 1018 Printer
Ricoh Aficio AP2600 Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
