Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Freezer evaporator frozen over
The evaporator was frozen over and the fridge side was not getting any air. How do I know if the evaporator fan is bad? Is it supposed to run all the time, because it's not running at all. Or am I looking at the wrong problem?
You a got problem on your defrost timer
Posted on May 13, 2007
SOURCE:
Freezer works but refirgerator is not cold
when you open the freezer door do you hear the fan blowing?if not you have a bad evap fan motor,if the fan is blowing put your hand on the back inside wall of the freezer,if you feel like snow on the back inside wall you have a defrost problem and have to find what part is bad with a meter,bad defrost thermostat,heater or board or timer,send model number next time,ice builds up on the coil and air can't blow into fridge from freezer,could have a bad damper,also if the freezer is on top you could have a blocked drain in the freezer,the air vents freeze up and the fan can't blow air from freezer into fridge because the air ducts are frooze up,all it does is the freezer gets cold,the evaporator fan blows cold air from freezer into fridge section,so either the fan motor is bad,the fan blade is damaged or something is blocking the air like a bad damper or air ducts are frozen up,send the model number and let me know what you find,do you hear the fan,any ice on back freezer wall or anything else you see and i'll try to help you out.
Jun 02, 2012 | Refrigerators
Wawwwwtewwwwwar
Hi!!
Make sure drain hose is not clogged up. Check evaporator fan, (small fan in freezer compartment). it should come on after door is open a couple of minutes. Feel air vents in fridge side for a stream of cold air, if none or too weak, remove back cover (where fan is) and check for frozen evaporator coil. If evaporator is frozen, air can't circulate thru unit, keeping fridge side from cooling and freezer side below freezing point.
If this is the case, unplugg unit from power outlet, and use a heat gun or hair dryer to melt ice, make sure all vents are clear.
Once the evaporator coil is free of ice, dry freezer, replace back cover and plug unit back on. Check temp. settings, should be about 1/3 of the dial range. If necessary, make additional adjustments every 24 hrs.
Don't forget to rate this post!! Good Luck!!!
Jul 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer iced fridge 50 F
You obviously still have a defrost problem so here is info to help solve it.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 21, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
Freezer works, fridge doesn't
Sep 27, 2009 | Refrigerators
Cleaned the coils but freezer not freezing and inside not getting cold what is wrong
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged 5. defrost cycle not functioning properly if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. there defrost cycle starts with the timer. at a certain time of day for a specific time, the timer turns the compressor off and turns on the heater element located at the bottom of the evaporator coil. this stays on until the coil temp sensor reaches a certain temperature to let the timer know that the coils are defrosted and turns off the power to the element. the defrosted water drains to the condensate pan. if the timer is bad, it will never go into defrost, or never get out of it. if the element is bad, the coils will never defrost. if the temp sensor is bad, it?ll go into defrost, but it will either tell the timer that it?s always frozen or already defrosted, resulting in the element never turning on (stays frosted) or never turning off (eventually burning out the element). defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Sep 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Apr 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
137 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
