Question about Konica Minolta magicolor 2300DL Laser Printer
Paper stuck Paper always stuck during the first page print.. Top roller very hot and every 2~3 pages print, the paper will stuck again. Then, I have to off and restart the printer to print the next page. Should I replace the roller?
  • reepher Jan 13, 2009
    I have a very similar problem. The first page printed after wake-up always comes out folded near the top. The next few pages print fine, then perhaps another folded page. Also increasing numbers of media jams early in the transport process. Other users on this forum are reporting similar issues. Is our printer nearing EOL?
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
HP laserjet 1518
HP printers frequently time how long a page takes to run through the machine. If it is too slow, they signal a jam error.
Try cleaning all the rollers and pinch wheels etc within the laser.
Dec 10, 2013 | HP LaserJet Office Equipment & Supplies
I have two HP2025's with the same problem, if I try to print a multi page document the 2nd page always jams... I have had both printers checked for paper pieces stuck somewhere but there is none. Total...
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Sep 05, 2011 | Office Equipment & Supplies
Printed image repeats later
I have a Dell 5100CN, and believe that this problem is caused by the drum not releasing the full charge which holds the ink in place on the drum until the page is printed. After the image is transfered to the Drum, the 'Fuser' unit heats up the paper and pressure forces the paper against the drum to transfer the toner from the drum to the paper.
Since the Image is printing, and you are getting a ghost, I guess that the problem is most likely the 'Pressure Roller' or 'Heater' in the 'Fuser' unit.
Buying the Fuser unit from Dell could cost you around $200 from Dell, but I just found one on eBay for $129 Got to www.ebay.com and search for item number 190388919845
I highly recommend that you buy a new OEM (original Equipment Manufacturer (Genuine Dell)) 'Fuser Unit'
Good Luck
Apr 23, 2010 | Dell 3010cn Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
"always getting check paper size"
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
Dec 08, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Sqeaky paper feed
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=238800&prodTypeId=18972&objectID=c00001617 the HP site for your printer Over time, particles of toner and paper accumulate inside the HP LaserJet 2300 series printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Clean the paper path and print-cartridge areas every time that the print cartridge is changed or whenever print-quality problems occur. As much as possible, keep the printer from dust and debris. Cleaning the outsideback to top of page Clean the outside of the printer with a cloth that has been dampened with water. NOTE: Do not use ammonia-based cleaners on or around the printer. Cleaning the paper path and print-cartridge areasback to top of page Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Use the following steps to clean the paper path and print-cartridge areas: 1. Turn the printer off and unplug the power cord. 2. Open the top cover. Figure 1: Top cover opened example 3. Remove the print cartridge. Figure 2: Print cartridge removed example CAUTION: To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.Be careful not to touch the transfer roller (the black, rubber roller located underneath the print cartridge). Skin oils on the roller can cause print-quality problems. 4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity. Make sure not to touch the transfer roller with fingers, as the oil can contaminate the roller, resulting in print quality defects. Figure 3: Paper path area and print cartridge cavity example 5. Reinstall the print cartridge and close the top cover. Figure 4: Print cartridge reinstalled example NOTE: If the print cartridge is difficult to reinstall, make sure that the registration plate has been flipped back down into position and that the print cartridge is pushed firmly in place. 6. Plug in the power cable and turn on the printer. Cleaning the fuserback to top of page Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of print jobs. To ensure optimum print quality, HP recommends using the cleaning page every time that the print cartridge is replaced or on an automatic pre-established interval. The cleaning procedure takes about 2.5 minutes to complete. A message (either CREATING CLEANING PAGE or CLEANING) appears on the printer control panel display while the cleaning is taking place. NOTE: Use plain paper to print the cleaning page. Please note that this is a two-step process. First print out the cleaning page using the following directions, then follow the directions on the cleaning page itself to reinsert it back into the printer to perform the cleaning. Use the following steps to run the cleaning page: 1. If the printer model includes a duplexer, open the rear output bin. 2. Press example(Select button) to open the menus. 3. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE, and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY, and then press example (Select button). 5. Use example (Up button) or example (Down button) to scroll to CREATE CLEANING PAGE, and then press example (Select button). 6. Perform the following to complete the cleaning process. 1. Remove all paper from Tray 1. 2. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE and then press example (Select button). 3. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PROCESS CLEANING PAGE and then press example (Select button). 5. Load the cleaning page created in step 5 above into Tray 1 with the print side down and the arrow towards the printer. 7. If the printer model includes a duplexer, close the rear output bin. Let me know if that helped. Good luck, Tim
Mar 14, 2007 | HP LaserJet 2300 Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
125 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
