Question about Garden
I have a stihl 009 chainsaw. There are two fuel lines from tank. One the carb. What is the other one hook up to?
2 Suggested Answers
  • 3 Answers
SOURCE: i need fuel line routing for mcculloch fr2.0 chainsaw
primer bulb... long barb goes to fuel tank pick-up.... short goes to carb.... make sure the new tubing is safe for the damn ethanol fuel and that it fits snug thru the tank or it will leak
Posted on Aug 18, 2009
Testimonial: "thanks"
Why is the fuel tank for 381chainsaw not having pressuer to push fuel
they do not have a pressurized tank gravity only .
Aug 09, 2016 | Stihl Garden
Fuel lione and filter came off in the tank
This is a simple repair.
1. Drain tank save fuel can be used again
2.Purchase fuel line replacement kit Lowes -Home Depot
3.Kit needs to contain feed wire and gas hose.
4.Disassemble cover to reveal fuel line connection to carb.
5. Feed wire from kit into fuel tank through fuel line hole.
6. Install new hose over wire connecting end into hook at end of wire
7. Pull hose through tank up to the carburetor
8. Remove wire and connect filter and hose to carburetor
9. Replace gas into tank, Ck for leaks
Nov 15, 2015 | Stihl HT101 Pole pruner
Stihl 012 av fuel lines
The 2nd line might be a vapor return line back to the fuel tank? I've dealt more with repairing bigger saws more than smaller ones. You should go to a Stihl shop&take a look at chainsaws about the same size as yours&take off the air filter cover&look to see where the carburetor lines go.
Aug 01, 2014 | Stihl 011avt Brake Handle 009 010 011 012...
Stihl chainsaw problems
Your dealer is right. Gas is not a carbs best friend. every time you fuel dirt gets in the fuel tank from the air. This eventually blocks air and fuel passages and check valves inside the carb. That is the reason. Carbs wear out like anything else. Check the price of a carb compared to a kit. Some Stihl carbs are reasonable.
Jul 21, 2014 | Stihl Garden
Need a diagram of fuel line system for a 311y chainsaw
http://www.doityourself.com/forum/outdoor-gasoline-electric-powered-equipment-small-engines/279941-stihl-chainsaw.html#b
  1. Stihl Chainsaw - DoItYourself.com Community Forums
    www.doityourself.com/forum/outdoor.../279941-stihl-chainsaw.html
    Oct 4, 2006 - I am in the process of rebuilding my Stihl chainsaw carb. I am having troubles identifying this Stihl model. The only sticker on the saw is 311Y.
Mar 22, 2014 | Stihl 311y
No pilcoming through 009 stihl chainsaw
Check to make sure the pick up line in the tank hasn't come lose. Then check the port under the bar and cover is free and clear of debris. If that's not it you probably need a new pump.
Jan 29, 2014 | Stihl Garden
Stihl fs80av
generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Oct 13, 2013 | Garden
Have a Stihl chainsaw (011). It dies out at a high rpm. I think I am sucking air from tank area because carb. is good, fuel is good, fuel lines are good at carb. I am looking for something to print out...
Replace the fuel cap. Check the fuel filter (inside the tank hanging on a length of fuel line) for plugging. Also check that length of fuel line for decay or other damage. Hope this helps!
Dec 03, 2010 | Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
