Question about Dometic Refrigerators
Dometic rc1180 not cooling down on gas
On holidays and my dometic chescold rc1180 camp fridge works well on genny power but fails on gas. Pilot light on and can feel heat coming out though flue. Have got it level. What else could be wrong?
    Top Expert:
  • Dometic Master
  • 8,502 Answers
Clean all LP lines to ignitor if no clicking replace board
Posted on May 30, 2016
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
VtToolMan
  • 704 Answers
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Posted on Jul 30, 2009
  • 94 Answers
SOURCE: tent trailer fridge works fine on 110 , but does
This is normal on mine. The frig hasn't been like the one in my home but helps. You are camping you know. Refreshments go in the Icechest!
Posted on Aug 22, 2009
  • 4 Answers
SOURCE: dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Posted on Aug 23, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a Dometic
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 11, 2011
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
How to replace heating element in a chescold rc1180
open back unplug remove from stack inset new one and plug in
Dec 17, 2012 | Dometic 120V 325W Refrigerator Heating...
How to replace 240v element in chescold rc1180
open back access two black wires going to chimney and board
Hi...recently purchased a 2005 Roadtrek RV with a Dometic RM 2354 fridge in it...was getting things ready for camping and had the RV hooked up to 110 power...pushed on button for fridge and went through...
You said there was NO lights on the unit. The Dometic service manual says:
1. No operation - no panel lights: DC Volts
Fuse
Wiring
Upper Circuit Board
Lower Circuit Board
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
I would start with the DC volatage and track it back until you lose it. Most of the time it does end up being the lower circuit board though.
Aug 03, 2011 | Dometic RM2652 Refrigerator
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
Chescold rc1180 users manual
It appears that your brand branches off to many first name brand's like=> Chescold RC1180, 50 litre, 3 way, (12v,Gas,240v)
Here is the user manual=>
Combi Box 3 Way Fridge & Freezer RC1180
sea_breeze_111.jpg Caravan's Plus
RC 1180 EGP Fact is I could see so many different versions I am leaving you with a few extra divisions of Dometic. Should you need more answers please let me know, Thanks, Sea Breeze Please rate this solution. Sea Breeze
Mar 13, 2011 | Dometic Refrigerators
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Chescold caravan fridge 3 way fridge, (out on the bench not in a van) works well on 240V but not on gas. Pilot looks good, fridge is level, I have tried inverting the fridge as suggested. No luck. I can't...
Yep same prob as my Chescold model RC1180. I pulled the entire gas circuit apart as the fridge works well on 240v haven`t yet sussed the 12v.
I suspected the thermostat ( on the gas side ) there is a tiny jet on the side of the aluminium block at the base of the electric thermostat, also another springloaded 'valve' at the bottom of the aluminium block.The ' valve' is actuated by the thermostat Dial, as it screws a pin down onto a plate which departs from an O' Ring seal letting gas into the chamber where the tiny Jet is seated.This tiny Jet meters the gas to the Pilot burner.
Anyway ' That' wasn`t the problem! lol
The Problem was a 'Clogged Pilot flame Jet'
Fix..... I stripped as piece of fine electrical wire 12v and cleaned the jet out. It is a # 26.
The Jet itself looks like it has been 'Stamped' out rather than Drilled, this may account for some fridges working better on gas than others as there seem s to be some distortion on the Jet Orifice. I will buy a new Jet and a #26 drill and replace the original one.
I am just testing the fridge on Gas now...going like a Trojan... bonus is ive got a little 3 sausage hot plate over the Gas exhaust and am cooking dinner while the beer is getting colder !
K
Dec 06, 2008 | Refrigerators
Refrigerators Logo
215 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
