Question about Nespresso C100/T-US-AERO Espresso Machine
Nespresso le cube will not pierce coffee capsules
5 Suggested Answers
twoduckster
  • 370 Answers
SOURCE: My le Cube is puncturing
everything I can find on your machine, does not cover your problem. I have a Krupps. do mine the old fashion way. All I can think of( I downloaded every manual on-line I could find, and went to their site(found nothing), is in my thoughts was to insert the capsule, pull handle for the holes, release it, and turn the capsule around, to get the other holes you need. I am so sorry I can't find you an answer.. Twoduckster, ,
Posted on Jan 06, 2011
  • 3 Answers
SOURCE: My machine is a cube
stop being such a fuckig bum and throw that piece of **** out the window....it was trash before you bought it...if you saw a rotten piece of steak, would you put it on your kitchen counter...no, so why would you put this hunk of **** in your window. If you are considering trying to fix this metal pile of ****, do yourself a favor and beat it with a hammer. This retarded machine will probably work better.<3
Posted on Apr 03, 2011
  • 1833 Answers
SOURCE: Nespresso C190 is not piercing the top of the
According to your problem first open the coffee container and clean it properly. After cleaning fill the container with proper quantity of coffee beans. May be the spout holes are blocked. So clean the spout by pin. Also make clean the infuser by open the front cover of the infuser. The ground coffee may be blocked in the funnel. Remove the ground coffee inside the funnel using a knife. Then clean the infuser and the inside of the appliance. Descale the machine. It will help you.
Posted on Jun 13, 2011
SOURCE: No coffee comes out, only
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
Posted on Dec 13, 2011
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
Why my nespresso c110 cofee machine will not pierce the top of the pod and thereFore no coffee.
Are you using genuine Nespresso capsules? Any other kind will cause the machine to malfunction.
Feb 13, 2015 | Nespresso Coffee Makers & Espresso...
Nespresso magimix
Check the relay on circuit board
Jul 20, 2014 | Nespresso Le Cube
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
The pods are not being pierced and the coffee is coming out too weak. Help!
The capsules are not pierced when they are inserted. They are pierced on the back but not in the foil. The foil is pierced when the hot water is injected through the posterior holes and the pressure causes the foil to bulge, thus getting pierced by the grid in the front of the machine. If the capsules are not getting pierced it means that the water is not being injected with enough pressure. This could be due to hard water deposits. Try first to pump the machine by turning it on and then lifting the lever and keeping it raised for a few seconds. If that doesn't work, de-scaling the machine should correct the problem.
Aug 10, 2011 | Nespresso Essenza D100 Espresso Machine
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
Le Cube: Water does not flow after tank in Le cube ran dry....
Open the lever (the one on top of where you put the pod, and keep pressing it backwards until water comes...
May 18, 2010 | Nespresso Le Cube
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Where can I download the manual?
The manuals are available on the Nespresso website (www.nespresso.com). Click on the "machines" section, and then choose the le cube. Click on the details page (https://secure.nespresso.com/precom/sima/fiche__NESPRESSO_Le_Cube_D185__N_D185_1_us_en.html) and you should see the link for downloading the manual. You can also download the descaling instructions as well.
Aug 06, 2008 | Nespresso Le Cube
Nespresso C100/T-US-AERO Espresso Machine Logo
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
