Question about HP Officejet 5610 All-In-One InkJet Printer
Need help...printer will not scan
It says refer to documentation to troubleshoot
  • 1 more comment
  • HPC8180 Jan 03, 2009
    I have the same problem with my HPC8180. I can't scan to the computer, but allows other scanning options.
    Also, HP Solution Center will not open.
  • bfadair Mar 22, 2009
    cannot scan to computer, can scan to to memory device connected to network via ethernet
    cannot scan either
SOURCE: Printer Won't Scan
I cant scan it says refer to documentation to troubleshoot. How do I fix this. Ishala
Posted on Nov 25, 2008
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
  • 5 Answers
SOURCE: When trying to scan to my HP J4580 Officejet J4580
this means the printer has not been configured to the computer,,
1st check the connection of the printer and the computer,,
then check if all the software like the basic print and scan drivers, hp solution center and the hp imaging device function had been installed or not,,
if all the above things had been checked then
open hp solution center,,
click settings,,
go to scan settings,,
select scan to set up.....,,
you will get two columns there,,
the left will be for the solution center and the right one will be for the printer,,
you will see two arrows in between the columns,,
populate the entries on the printer that is on the right column using the arrowes,,
once done click update device,,
then close the olution center and restart the printer,,
then check it will work................
Posted on Feb 16, 2010
puertobori
  • 7733 Answers
SOURCE: My printer won't scan to my computer. I get a
try Using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Posted on Oct 28, 2010
Testimonial: "Thank you! Very easy to fix with some expert guidance."
puertobori
  • 7733 Answers
SOURCE: i want to scan a document on HP officejet J4680
Posted on Oct 29, 2010
Testimonial: "found link last night. it worked perfectly and fixed problem. Thanks."
It won't scan. It said that there's no scan option and to refer to documentation for troubleshooting
it won't scan. It said that there's no scan option and to refer to documentation for troubleshooting
Jun 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan and transfer to outgoing email??
Hi. Here are the steps you need to do to send a scanned document/image using your default email application. Place your orinal document/image on the printer. Using the Productivity Studio software, click email, select the scan type (photo, several photos or document). Click start. Click create email to attach the file to the email message. Hope this helps. There's also a PDF file User Guide you can download from the Lexmark website for your reference. Just click on this link: http://bit.ly/9gZV0u . Click on the 9500 Series All-In-One User's Guide found below the page. Download the PDF file. Refer to Scanning page for concerns about scanning. Good luck!
Mar 22, 2010 | Lexmark X9575 InkJet Printer
Cannot scan any documents to computer. Refer to
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
Cannot use scan...when I put a document in the tray and press "start scan" it says " no scan options" and "refer to device documentation" what to do?
You need to have it connected to a computer with the scan software running. The scan options are in the computer. It tells what type of document to scan, how to save it, JPG, PDF, etc. and where to send the scanned image.
Oct 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Need to scan - unable to on my HP officejet 5610xi All-in-One
open control panel -> go to scanners and cameras -> start the hp officejet 5610xi -> then it should start enjoi :)
Jan 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanning
you need an application software to scan a document first, install one from your manufacturer's CD and follw the direction carefully, or if your computer recognizes
go to start-program-accesories-then scanner and camera, see if your computer recognizes your scanner.
Aug 16, 2008 | HP Officejet 6310 All-In-One InkJet...
Printer Won't Scan
Mar 29, 2008 | HP Photosmart 3210 Printer
Scanning
go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Dec 17, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
