Question about Dell Inspiron 6000 Notebook
Laptop screen is very dark even though harddrive is running fine
Computer screen very dark no backlight when computer is on
  • Anonymous Feb 14, 2009
    My dell 630m laptop screen is dark even though the hardware
    is running fine
    Scholar:
  • 39 Answers
There are several reasons this could be happening but lets try adjusting your brightness/contrast settings.
Go to; Start Menu > Control Panel > Power Options
You should see something like this.
http://i298.photobucket.com/albums/mm260/mshockey89/Tech%20Support/Poweroptions.jpg
On the left hand side of the screen select Adjust the Display Brightness. You should see somthing like this.
http://i298.photobucket.com/albums/mm260/mshockey89/Tech%20Support/EditplanSetting.jpg
Now just play with the brightness settings until you get the desired effect.
Also, make sure you don't have the brightness settings too low for your off battery settings. This could be a reason as to why your having this issue. If this doesn't fix the problem, let me know.
Posted on Jan 03, 2009
Sometimes when I start my HP pavillion dv5 2135dx laptop the screen is dark even though the computer is up and running. It may take several shutdowns and startups for the screen to finally come on. Other...
If you can very vaguely see the icons or pictures displayed on the screen even though dark it maybe either a problem with your inverter or Lcd backlight. If no images are seen even though you look carefully then it may be the onboard vga controller. It maybe worth checking to see if your laptop is under warranty with Hp see link.
h10025.www1.hp.com/ewfrf/wc/weInput
I
Feb 27, 2011 | Computers & Internet
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
I have a Sony Viao NS10E, all working fine and then the screen went dark, took screen out and put in an other laptop and it worked fine, put the screen from the other laptop in mine and still dark. The...
You definitely have a Video Card Error related.
  1. Find Where Your Graphic Card located (asuming your computer has a separate card for video .
  2. Check the connection from your display to your video card (these connections are very thin wires running all the way to the video card or the MB).
  3. If the second step is clarified then have your graphic card checked. or have *********** Board chip set checked for bios and fermware.
Mostly you have a connection problem.
Nov 27, 2009 | Sony VAIO PCV-W20 PC Desktop
My screen is dark when the computer logs on (but I
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness.
Sep 24, 2009 | HP Compaq nx9030 Notebook
Blank screen on laptop
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 27, 2009 | HP Pavilion dv9000z Notebook
The screen is not lit
This is most likely your backlight CCFL tube or Inverter. Unless you are very confident and experienced at laptop repairs, you should take this into a repair shop to be fixed. It will only need a £10 part. I recently replaced my backlight and it cost £9.99.
Dec 17, 2008 | Acer TravelMate C110 Tablet PC
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 6000 Notebook Logo
305 people viewed this question
Alun Cox
