Question about Grundfos UP10-16B5/ATLC Comfort Series 1/33 HP Recirculator Pump with Sweat
What's the options for the settings of the thermostst and how do you do it ?
There's a dial on top of the pump for setting the thermostat what does that dial exactly do.? There is a low end and a high end on which is the symbol of a thermometer crossed out.
  • Grundfos Master
  • 5,089 Answers
Most recirculation pumps can operate in 2 different modes.
Timed mode where you schedule times of day on face of analog timer that rotates like a clock, or thermostat mode where the pump runs when water inside pipe drops below 90 degrees.
The selector switch lets you choose which mode.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Posted on Oct 26, 2012
How will i know if my themostat has been removed on my puma 1.7.and where is it situated in my engine
the thermostst is normally situated at the engine end of the top hose in a housing. To check wait until the engine is cold Thermostat will be shut remove the top radiator hose at the radiator and start the engine If water gushes out there is no thermostat. Best to get a friend to start the car as it will pump out quickly
Jan 17, 2013 | Ford PUMA Cars & Trucks
I would like to turn fan on and off from thermostat fan only nortron electric furnace
you can change the thermostst to anyone u like in the store either digital or manuel all the wires run the same and are color coated each thermostat has the settings shown buy the one with the settings u desire and one that is easy to control for you
Mar 14, 2012 | Heating & Cooling
I need to locate my thermostat and change it
follow top rad hose to motor under housing where hose connects put new one in the correct way spring goes to engine side
Aug 05, 2011 | 1992 Plymouth Voyager
My Westinghouse RS662V fridge is not cold at all. I have turned the dial to full cold but it has made no difference. The freezer seems to be working OK. Could it be the thermostat in the fridge?
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Frigidaire FRT18G4A Top Freezer...
AC IS TURNING ON BY IT SELF AFTER I SWITICH IT OFF, HOW TO SOLVE THIS PROBLEM
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
Where is the thermostat located
Follow the top radiator hose to where it connects to the engine block. The thermostat is under the domed hose connection on top the motor.
replacing the thermostst involves.
  1. Partially drain the coolant, (until the level is below the thermostat).
  2. Remove or disconnect the following:
    • The air cleaner and duct assembly
    • The crossover exhaust pipe
    • The radiator hose from the thermostat housing
    • The thermostat housing bolts
    • Any remaining sealer from the bolt threads
  3. Rplacing the thermostst is as follows
  4. Install or connect the following:
    • The thermostat
    • The gasket NOTE: Apply RTV sealer, GM P/N 1052366 or the equivalent, to the thermostat housing bolt threads.
      1. Torque to: 18 ft. lbs. (25 Nm)
    • The radiator hose to the thermostat housing
    • The coolant
Feb 09, 2011 | 1999 Oldsmobile Silhouette
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
R55 model. runs for a while & cuts off. [1]
Dials? I assume you are speaking of the air pump adjustment screws.
How to set the pump pressure
Nov 20, 2010 | Reddy R60A Utility Heater
Should the settings be different from the top and the bottom thermoststs
No, It will not hurt anything except wear out the thermostat a little quicker. (The one thats higher)
The unit will be more efficient, especially at high use times if both t-stats are at the same temp.
Sep 06, 2009 | Water Heaters
My Amana LWA60AW washing machine won't agitate.
Some timer dials will not turn all the time they will sit for awhile then advance . If it don't move for a long time sounds like you have a bad timer motor.
Some motors can be replaced and some you have to replace the complete timer.
Jun 10, 2009 | Washing Machines
Grundfos UP10-16B5/ATLC Comfort Series 1/33 HP Recirculator Pump with Sweat Logo
88 people viewed this question
Top Grundfos Hardware & Accessories Experts
Gene Haynes
Mike Magnay
Mike Magnay
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
