Question about Behringer X V Amp Guitar Multi Effects Pedal
Common Issues with Behringer X V Amp Guitar Multi Effects Pedal
3 Suggested Answers
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
  • 5603 Answers
SOURCE: My Behringer fx600 multi effects
The LED is ALSO used as a battery condition indicator... this is probably indicating the battery is expired. The manual sure doesn't say much!
Posted on Apr 26, 2011
How to hook up my Behringer V-amp pro
Hook it up to what? You'll probably want it in the insert on the guitar channel.
Nov 30, 2013 | Behringer V Amp Pro Guitar Multi Effects...
Behringer x v-amp pedal creates no sound through my amp only an drone that sounds like electrical feedback?
I have one, and IT WORKS for me!
As the manual suggests, the 1st step is to RESET your pedal board. I know, you 'll have to erase 20 custom presets of yours but hey, they're already lost anyway!... So just reset the on board chip by pressing the TAP and STORE buttons together for 5 seconds while you power ON the X V-amp. That's it! Now the board sounds good as new!
http://guitar-dreamer.blogspot.com.br/2012/11/behringer-x-v-amp-easy-fix.html
Apr 21, 2012 | Behringer X V Amp Guitar Multi Effects...
My guitar wont connect through the behringer with my amp :(
Check battery and or power adapter and that the input and output cables are not backwards.
Jun 20, 2011 | Behringer Sm400 Super Metal Distortion...
I don't know how to put batteries into my "Digital Multi-FX FX600 Behringer" Effects pedal. -_-
Most of these the battery is UNDER the pedal itself. You push in on the hinge pins with a pen to release and remove the pedal and change the battery.
Apr 28, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
My Behringer fx600 multi effects pedal flashes rapidly when used with a power adaptor. this happens whether the pedal is turned on or not.
Apr 26, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
Hi , i have a Bugera 1960 and my problem is send-return...when i put my boss ge-7 equalizer in it i can t hear the fx and this is the same thing for my delay pedal...i can hear but realy realy little...
The problem is the BOSS is designed to handle a guitar level at -20Db and the effects level is designed to run at either -10 Db or +4 Db. You will get better match setting the Bugerra effects to the -10 setting on the back and reducing the level... HOWEVER the pedal will want to send -20Db out which is 10 Db under what the effects return wants to see. This is a factor of three roughly in gain so the signal will be low. This is the problem using a guitar pedal in a way it wasn't designed to be used. The effects loops are looking for "line level" NOT guitar levels.
Schematics aren't going to help. The normal thing is to connect your guitar to the pedal and send the output of the pedal to the amp.
Guess what? The same things apply to your delay pedal... they are intended to accept the signal from the guitar OR the guitar like level from another pedal such as the GE7.
Mar 17, 2011 | Behringer Bugera 1960 Classic 150-Watt...
Basically i cannot seem to make the pedal work in tandem with my crate flexwave 120w 2x12 dsp amp i prefer to use the built in dis,chorus, and delay effects but can find no way to put the hb01 behind the...
Norrmally you run the guitar into the pedal and then into the amp. IF you want it behind the built in effects, The look on page 6 of your users manual showing the special cable you will need to do the "insert" of your effects pedal.
If you don't have a manual, download it here:
http://www.crateamps.com/pdf/manuals/FW120H_OM.pdf
Jan 11, 2011 | Behringer HB01 Hellbabe Wah Pedal
How to reset my Zoom G1 Guitar multi effects pedal
Here is a link:http://s3.amazonaws.com/samsontech/related_docs/G1_G1X.pdf Pay attention to page 25 Restoring Factory Defaults.
Jul 16, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Behringer X V Amp Guitar Multi Effects Pedal Logo
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
