Question about Sangean DT-120 AM/FM Radio
My sangean dt120 shuts off after 10 seconds, battery is good
When the alarm activates on my Sangean WFR-28, I can see the preset station showing up on the screen but there is no sound, although the volume is set to 20.
I have the same issue with my Sangean WFR-28c. I just contacted support (through Sangean Europe site) but im still wating for an answer. If this carries on, i cannot use this radio. :(
Nov 16, 2016 | Sangean Audio Players & Recorders
How can I stop my Sangean DT 120 from shutting off after 5 seconds??
Does it have an automatic shut down system? You know in case it is absconded?
Jun 01, 2015 | Motorcycles
My radio shuts off after 5 seconds.How can I fix this?
Maybe you have a timer to shut it off in 5 secounds? Check your user's manual
Jun 01, 2015 | Sangean DT-120 CLEAR Pocket AM/FM Receiver...
What does a flashing E in the LCD mean?
Try checking the correct power supply, and batteries. ("E" = error)
Sep 24, 2014 | Sangean ATS 808A AM/FM/SW Radio
I have a Sangean ATS 818cs portable radio but no 6v lead input
Yes you can use any 6 volt DC for your radio but the most IMPORTANT thing to remember is to connect the terminals in the correct direcction. First of all you can solder a red wire from the positve terminal of the battery and a black wire from the negative terminal of the battery. This must be connected to the source of your 6 volt battery.You can buy a good DC jack socket female to be fitted into the vacant spot of your radio and use a male jack to supply the DC. Only be carefully to see the polarity. To avoid any reversing of polarity use can even connect a diode in the forwarrd bias towards the positve terminal. This will prevent any wrong connection of polarity to damage your set. Helpful? Good day
Jul 13, 2010 | Sangean ATS 818 AM/FM/SW Radio
Lost battaries compartment cover
I lost my radio shack sangean 909 battery cover too! where do I get a replacement?
Jan 26, 2010 | Sangean ATS 909 AM/FM/SW Radio
My system asks for installation of my 4GB DT120?
RESTART THE SYSTEM AND PLUG IN THE PEN DRIVE IT WILL WORKS.WHY IT ASK THAT YOU SHOULD INSTALL YOUR 4GB DT120
Sep 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sangean ATS 803A
Don't be mis-led by the working display. I had the "no power" problem with a working display too. I measured the voltage of the two AA batteries. One was 1.33 volts and the other was only 0.76 volts. Replaced the weak AA and everything worked. I suspect the 'enable' circuitry fails around/below 2.1v.
Sep 27, 2008 | Sangean ATS 808A AM/FM/SW Radio
Sangean ATS 606 A Portable Radio
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Aug 15, 2007 | Sangean ATS 606 AM/FM/SW Radio
SANGEAN ATS505
try the power switch a few times and more force than usual.
Sep 16, 2006 | Sangean ATS 505 AM/FM/SW Radio
Sangean DT-120 AM/FM Radio Logo
115 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
