Question about GE Microwave Ovens
JVM1870SK03 ge microwave fan turn on whenevr we close the door
The plate does not rotate
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is a shorted main relay on the control circuit board, which we regularly repair with our $39.95 service.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
JVM1870SK03 ge microwave fan turn on whenevr we cl - 10_26_2012_5_00_00_pm.jpg
Posted on Oct 26, 2012
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 23, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Posted on Jan 31, 2009
ginko
  • 19396 Answers
SOURCE: light bulb not working on my ge microwave model JVM1870SK03
Replace the light bulb, if that is not enough , check contact to lamp holder.
If microwave is not working at all, check also door switch , fuse, and control panel.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
SOURCE: Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Posted on Mar 27, 2010
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
Light bulb not working on my ge microwave model JVM1870SK03
Apr 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave Ovens Logo
107 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
