Question about Dishwashers
I HAVE A ELECTROLUX DISHWASHER MODEL EIDW6105GS1 WITH A LEAK DETECTION LITE ON, IT QUITS ITS CYCLE WHEN IT COMES ON.
5 Suggested Answers
  • 423 Answers
SOURCE: Dishwasher states there is a water leak when visually there isn't
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection (sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
Posted on Mar 28, 2009
tattootech2
  • 72 Answers
SOURCE: EWDW6505GS0 Model Electrolux dishwasher 10 months
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
rylee_smith
  • 8619 Answers
SOURCE: dishwasher quits running and clean lite keeps flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
SOURCE: Our dishwasher model eidw6105gs1 will not start.
Think you need to reset it, leave it turned on overnight and door shut firmly, sometimes the problem is programme can not be finished from before.
Posted on Dec 01, 2010
Electrolux eidw6105gsi
Good Morning Friend,
I understand that your Electrolux dishwasher, model# EIDW6105GS1, is not cleaning your dishes. I ask that you please try the following solutions:
    1)Check the incoming water temperature. It should be at least 120 degrees F (49 degrees C).
    2)Choose another cycle for longer washing time.
    3)Check the rack loading section for proper loading-avoid nesting items.
    4)Make sure your home water pressure is not too low-it should be between 20 and 90 pounds per square inch (psi).
    5)Check water hardness. For extremely hard water, it may be necessary to install a water softener.
    6)Use fresh detergent.
    7)Make sure items are not blocking any of the spray arms, preventing them from rotating.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jun 19, 2014 | Electrolux Dishwashers
I have a EIDW6105GS1 all of the light flash! it did it once before and I thought I reset it somehow! but I cant remember! can you help?
There might be a possibility of resetting by pressing High Temp button 5 times. But I don't think this may solve the problem.
All lights flashing could mean a flood detection. This means water is leaking into the base of dishwasher. The flood switch has to be dried to make it work again. Also need to find the source of the leak. Make sure dishwasher is disconnected from mains power before attempting to work in it.
Apr 25, 2014 | Electrolux Dishwashers
Electrolux dishwasher eidw6105gs1 No power and no
Hello Pamela, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, and faulty power supply or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 03, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher model #EIDW6105GS1 My dishwasher was installed one and a half years ago and has worked beautifully and quietly until recently. The last three times I have washed dishes I hear the...
turn water off....remove the dishwasher....load it into the back of your pickup truck...take it to the recyclers....go to town and buy a different unit....NOT THIS ONE...this machine will never get any better...the only good thing about it is that it looks nice.....
Aug 29, 2011 | Electrolux Dishwashers
Our dishwasher model eidw6105gs1 will not start. You push the start and nothing happens. The lights are steady.
Dec 01, 2010 | Electrolux EIDW6105GB 24 in Builtin...
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electroluxe dishwasher starts and once water runs it quits working and all the lights on the display start blinking and it won't work. Any ideas?
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Dishwashers Logo
347 people viewed this question
Top Dishwashers Experts
