Question about Dryers
My dryer is making a thumping noise. Could it be the drum needs adjusting?
  • 14,411 Answers
Yes Rachel,the belt that turns the drum could be stretched and need replacing.
Posted on Oct 26, 2012
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
SOURCE: Dryer drum making thumping noise
My dryer just started making this noise. So I opened the back up to try to figure out what it might be, and when I opened it I saw something. It was part of the belt that drives the dryer. There are grooves vulcanized to the belt, and a small section of grooves or cogs I think is what they are called had come apart from the belt and what laying there on the floor of the dryer. But I ran it and timed the thumps in my head to get it to stop right on the "thump". Sure enough there was a small 1/2'' appx. of belt Cog missing, so the "thump" came from when the belt came around to the motor and the pulley hit a divit in the belt, "thump". So needless to say I need to replace the belt soon before it breaks completely. I figure that it looks like someone may benefit from knowing what the noise is. Now its off to find the proper belt and look up how to change those things...Good luck to those reading this.
jiujitsujd@aol.com
Posted on Mar 20, 2009
MNTECH
  • 1543 Answers
SOURCE: Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Posted on Jun 10, 2009
  • 5 Answers
SOURCE: dryer makes a thumping noise when running.
replace drum wheels.
Posted on Jul 16, 2009
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Kenmore 80 Series dryer's drum is making a thump
I would check all the screw's to make certain they are tight. That was my problem when mine was making noise. Look on the interior of the drum.
Jan 01, 2012 | Kenmore Dryers
Frigidaire LEQ215EE1 dryer making thumping noise
Posssibly have a bad drum roller if mechanically inclined you can do this yourself but you need to take the drum out to do this
Nov 15, 2009 | Dryers
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
LG ELECTRIC DRYER
Apr 04, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
196 people viewed this question
Top Dryers Experts
