Question about Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black
I no longer get a good signal from xm on my inno
I'm being shuffled between Pioneer and XM with no help yet. My inno breaks up worse then an am station. It doesn't matter if it's in the home dock or my car docking station. The signal constantly comes and go.
  • 1 more comment
  • Anonymous Feb 15, 2009
    Mine worked fine for the first month, then reception got progressively worse.  Reads three bars for signal, so antenna is properly placed.
    Mark
  • Anonymous Mar 17, 2009
    ya full bars and screen says check antenna. some days crystal clear others i want to throw it out the window
  • Anonymous Apr 11, 2009
    signal strength drops when I'm walking in different directions. Heading south, the signal is fine; however, when I make a turn...I lose the signal.
SOURCE: pioneer inno
I have the same issue. I was told a firmware upgrade will fix this issue
Posted on May 29, 2007
TOLhamRadio
  • 509 Answers
SOURCE: no signal problem on xm home satilite docking staion
You have probably lost a local repeater. Try moving it temporarily to a south-facing window. Here's another one to try: Put in dock and turn off with button on unit. wait 10 seconds, now press "2" "0" "7" "XM" buttons one at a time in that order ON THE FRONT of your SkyFi2 and the radio will go ON by itself! Now, press "Display" 4 times. You will see a screen that says "SAT1", "SAT2" and "TERR". You need a constant checkmark for DEMOD on at least one of the 3 boxes. Please tell me which ones are checkmarked and the average "BER%" number is. The lower the BER% number, the better. If BERis 100%, you are out of luck. Write back and let me know what you read. Press "Display" 5 more times to go back to regular screen. Thanks,
John
Posted on Aug 21, 2009
  • 11 Answers
SOURCE: my pioneer inno xm receiver is stuck on channel 1
Are you sure you gave them the correct radio id number?
Let us know if and when your problem has been solved.
Posted on Jun 11, 2010
  • 11 Answers
SOURCE: pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
SOURCE: cannot power up xm onyx radio in docking station;
I had the same problem, Bought a new Onyx and tried the supplied 12v power cable on existing Onyx and it worked, So it appears to be the power cable, Hoping now I can find a new power cable,
Posted on Dec 27, 2010
Won't power on
Have you tried plutting it in directly to the power source with out the battery? If this works, it may be that the battery is dead, you can try to jump it by putting the battery in after it has already been turned on. Or just replace the battery:
http://www.tss-radio.com/products/replacement-battery-for-pioneer-inno-and-samsung-helix-xm-radios
If it does not power on, it could be the power cord is bad:
http://www.tss-radio.com/products/xm-5v-home-ac-power-adapter
Otherwise, the unit itself may just be dead.
Jun 26, 2012 | Pioneer GEX-INNO1 XM Radio Receiver with...
My pioneer inno xm receiver is stuck on channel 1 and 234. have had xm reactivate my signal 3x since early this am. still cannot move to other stations, pioneer is closed for the weekend and the manual...
It sounds like the radio is not activated. If it isn't, go to xmradio.com and follow the instructions to activate it. If you have activated it, and you are still getting only two channels, either go to xmradio.com or call them and you can "refresh" the activation.
Feb 13, 2010 | Pioneer inno2 Portable XM Satellite Radio...
Inno will not work in car have good reception and no function on the inno for frequency, but can listen through headphones. external antenna is hook up also
Are you using a car dock with the sure connect wiring system, or an mp3 patch cord from the Inno to your auto radio with aux. input?
Jan 24, 2010 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer xm radio suddenly stopped playing through my car radio. Got xm to restart signal back to device but that changed nothing. Sometimes when I wave my hand near to the xm device the car radio receives...
I have same problem and sure connect did not help.
The unit works fine otherwise except will not send a signal to my car radio.
I will try removing the battery today & if this does not work I will do t paper clip reset in the battery compartment.
Sep 15, 2009 | Pioneer AirWave XM2Go Satellite Radio...
Pioneer inno will not recive xm singal
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
Inno music transfer!
If I understand correctly-you are saving the xm files in the xm format and thus can not be then moved to a cd or computer. You can take mp3 music though and add it to your inno but not the other way around.
Oct 20, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer inno
Have to use a car dock to use the fm transmitter.
Sep 29, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer Inno Gex-INNO2BK stuck in re-boot cycle
I fixed the reboot cycleing problem by plugging the travel charger into the jack that also fits the home and car cradle. I had the Inno set to auto start when it was powered on in the car cradle. The travel plug must have over-ridden the auto-start setting and allowed it to finish the complete bootup. I then reset the Inno default settings and every thing was back to normal. I do not know what was the original cause of the rebooting cycle problem
Jul 28, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Battery life
I know exactly what your talking about, I phoned the company and got the run around, somebody, anybody please help if they can!
Feb 20, 2007 | Pioneer XM2go Inno Satellite Radio...
Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black Logo
55 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
