Question about Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP
I need a wiring diagram for a 1994 30hp evinrude 4amp charger
2 Suggested Answers
  • 12 Answers
SOURCE: I need wiring diagram for 1968 Evinrude 55Hp
barbosam08.jpgbarbosam08_0.jpgbarbosam08_1.jpg These are specific to that motor.
Posted on May 23, 2011
I have a 1981 johnson 75hp charger. blew powerhead so i bought an evinrude powerhead that was omc identical. I have no spark. wiring issues.Thought johnson and evinrude was same wiring?
go google and type in --wiring schematics for johnson outboard motor 75 hp 1981 model --- and see if there is a pdf version for down load
repeat the search but change the name to evinrude and look for a pdf version down load
go to a dealer service center and see if you can get a schematics for each from them
while it can be expected that the wiring should be the same as each brand is made in a different factory there could be a slight difference in the wiring set up that is causing the problem
Aug 09, 2016 | Boating
I HAVE A 1978 EVENRUDE 35 HP NO FIRE TO THE PLUGS GREAT COMPRESSION???
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
Nov 26, 2015 | Boating
I NEED A BATTERY CHARGER
I do not know what kind of scooter you own, but this is a charger on amazon. If you include more info I can check for compatibility. NUMAX Mobility Scooter Battery Charger 24V 4AH 4AMP Connect Forget
Oct 16, 2015 | Health & Beauty
Wiring schematic manual
Check here,
http://www.kicksup.com/evinrude/
Aug 15, 2014 | Johnson Evinrude Starter-Outboard 97 V4-V6...
55973 A EVINRUDE Wiring Diagram IN COLOR FOR Free
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Nov 14, 2012 | Clymer Boating
I need to find and print out a wiring diagram for a 55 horsepower
here is the direct link to evinrude. There you will find what you are seeking.
http://www.evinrude.com/en-US/
Sep 14, 2009 | Boating
I need to find and print out a wiring diagram for a 55 horsepower 2003 Evinrude.
hi there,you can download a wiring diagram from
forums.iboats.com/evinrude hope this helps.regards barry
Sep 14, 2009 | Sport & Outdoor - Others
I am looking for a diagram of a 1977 evinrude 85hp engine - so i can work out how to remove the tilt rams from the engine to check if they are working correctly
Hi there, You can find all parts diagrams for Evinrude engines here: http://epc.brp.com Just ignore the email entry part and go straight to the database. They are listed by Brand, then year, then HP size. I checked for you and it has the 1977 85HP models listed there. Then just find the right subsection of the outboard and it will bring up exploded diagrams for your viewing!
Jun 15, 2009 | Boating
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
Clymer EvinrudeJohnson Outboard Shop Manual 48 235 HP Logo
107 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Steve
Steve
Are you a Clymer Boating Expert? Answer questions, earn points and help others
