Question about Toshiba E-studio 281c Copier
Toshiba studio 281c prints pdf in color not B&w
We have a Toshiba Studio 281c. Our default settings are to print black and white, with colour to be selected manually as an option. We have several pdf files which we send to the printer and specifically check that the settings are to print in b&w, yet when they print they print in colour - it seems that somehow the pdf file is overwriting the print settings request. Not specific to one machine - same on all machines - am thinking there is a setting on the actual printer but not sure where to look. any ideas? many thanks mel
chad7houston
  • 62 Answers
SOURCE: Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Posted on Oct 07, 2008
SOURCE: Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Posted on Feb 18, 2009
SOURCE: E-Studio 450 network issue
toshiba e-studio 450 black photocopy
I have machines, but I can not use the printer properties. If there is information about how appreciate if you provide information.
Posted on Jul 18, 2009
djuksoni
  • 103 Answers
SOURCE: How could i print pdf files with toshiba E-Studio 232
You need to buy GM1070 or GM1071,which are print enablers for es232.
Posted on Oct 29, 2009
007tech
  • 95 Answers
SOURCE: Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Posted on Feb 03, 2010
Why won't it print in colour?
Most likely defaulted to black on print driver. Change to color or auto color before sending print job.
Jun 23, 2014 | Toshiba E-Studio 2040c Copier
Cant print in color with e studio 281c I can copy in color
The 281c can be set to print to black only as a cost saving measure. The printer control panel is accessed through your browser (using the IP address of the printer) and the setting is made there. You should be able to override this through the printer properties in windows, but I have found that the PCL5 driver worked to switch between B/W and colour, while the PCL6 driver did not. So, for me the easy solution was to install the PCL5 driver and use that.
Apr 02, 2014 | Toshiba E-studio 281c Copier
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
My toshiba e studio 281c will not print in colour it will only copy in colour
Your print driver is probably set to monochrome. Usually there are to drivers set up on your computer: a pcl5 for black/white, and a ps3 for color--or vice-versa. Right click your driver; you can change the setting in your preference or properties section.
Oct 16, 2012 | Toshiba E-studio 281c Copier
How do you set the copier to scan as a pdf file all the time?
08-218
Default setting of filing for-mat when storing files (at color/ACS modes)
SYS 0: TIFF (Multi)
1: PDF (Multi) 2: JPG
3: TIFF (Single)
4: PDF (Single)
08-219
Default setting of filing for-mat when storing files (at black mode)
SYS 0: TIFF (Multi)
3: TIFF (Single)
4: PDF (Single)
5: XPS (Multi)
6: XPS (Single)
Jun 27, 2012 | Toshiba E-studio 281c Copier
Toshiba colour photocopier jamming when copying or printing in colour. error code cee0. O k in black
"CEEO" indicates Transfer belt position detection abnormality.
U need to service the transfer belt unit, especially the reflection tape and sensors.
Apr 01, 2011 | Toshiba E-studio 281c Copier
Printing in Color
what model if is Toshiba e-35 or e-350 all this machine is B & W you only can print in colour with e-3511 or 351C or 2500/3500 machine
Aug 12, 2008 | Toshiba e-Studio 350 Copier
Toshiba E-studio 281c Copier Logo
55 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
