Question about Maytag Neptune MAH5500B Front Load Washer
Nf pops up on the screen & the washer stops
I have a maytag neptune front load washer that doesn,t finish washing. the letters nf appears on the display screen & the washer stops until you hit the power button again
  • 1 more comment
  • Anonymous Jun 14, 2008
    I had the nf code - we live in Cincinnati - we have pretty hard water. The solution was correct. The end of the hoses were clogged with hard water sediment.
  • andrewbernar Sep 07, 2008
    Both the hot and cold water are on and the hoses are free and clear and are not kinked. I even checked the filters that the hoses to into on the machine and they are clear of any sediments. Still says nf right at the end of the rinse cycle every time, and the fabric softner does not empty into the machine. I need to turn off the machine and manually do a spin cycle to complete the cycle....frustrated!!
  • Anonymous Mar 15, 2014
    front load maytag washer stopped beeping
  • 5,911 Answers
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on May 13, 2007
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
Hello & Welcome to FixYa
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
It is displaying a nf and stopped working
NF means No Fill. Check inlet valve screens at the mix valve where hoses attach to machine. If there is nohumming noise at fill time, you will need to replace the inlet valve.
May 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer stops during the wash cycle and nf appears on the display screen
NF code is Washer does not turn on water valves to fill washer with water. You may need to replace your water valves, but I would first try removing your hot and cold water hoses to see if the screen on your valves is clogged. If they are corroded beyond repair, just pick up another set at the hardware store. Either that or you will need to do the valve replacement.
Mar 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code nf on display
nf code is no fill ,, washer does not turn on water valves to fill washer with water ,, , chk taps is the water turned on ? check inlet screens on hoses , check wiring connections in harness leading from machine control board to pressure switch,, check water valve ... check inputs and outputs at machine control board ,,
Dec 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune
Remove the water hoses from the washer and clean out the filter screens in the water valve.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE WASHER modelMAH6500AWW
It sounds like you need to cheak pump or drain hose for obstruction
Dec 18, 2007 | Whirlpool AWM029 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
4,969 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
