Question about Samsung Televison & Video
Cc4 test message on my tv.
We get the message CC4 Test Message appearing on the same channel everyday, different times but seem unable to stop it from happening.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Check to see if in closed captions the set or a box connected to it is NOT set to closed captions 4-----most sets have the option of cc1-cc4 and 4 is to my knowledge never used.
Posted on Oct 26, 2012
  • 8909 Answers
SOURCE: Problem, unable to access any digital channels. TV
If the database is empty you need to re load the system.
With your remote controller, go to menu and from that you need to select install or setup.
This will scan for all available channels and store them for use.
Hope that helps.
Posted on Nov 19, 2010
eagle338
  • 4889 Answers
SOURCE: I have a Panasonic Viera
Which site are you trying to access? I have seen this happen with netflix if you are not in the US, as its US only
Posted on Nov 24, 2010
SOURCE: 42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
Posted on Sep 18, 2008
SOURCE: when recording a channel and yo uchange to another "no signal" message appears on all other channels
one of the two leads going into the sky + box was loose.
Posted on Apr 15, 2009
jdvillanueva
  • 2098 Answers
SOURCE: Samsung DLP HLT6189S has 2
Yes this is fixable but based on the symptoms you've described, the problem is not only in one board but a lot of boards for malfunction like the power supply board, blue led display, Led driver board, and the I/O board.
This kind of symptoms is not a DIY and quite technical, I would advice you to ask for an estimate first to your local repair shop for service fee and parts lets say the parts above to have an idea how much money you are going to spend sending the unit in.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jul 11, 2011
Why can i print but not scan?
You probably need to re-install the print driver on the computer that is not scanning.
Apr 25, 2014 | Brother Office Equipment & Supplies
Cc4 205 00000012
Sir/Madam
To solve this issue, please install the latest scanner driver. If you use MFL-Pro Suite Software,
  1. Click Start => Control Panel => Programs => Programs and Features.
  2. Select Brother MFL-Pro Suite from the list, click Uninstall and follow the on screen instructions.
  3. Once the uninstallation is completed, disconnect the interface cable and restart the PC.
If you do not use MFL-Pro Suite Software,
Make a temporary folder on your HDD to save the downloaded self-extracting file, e.g. C:\bront
Please click here to download the uninstall tool to remove the drivers.
Once downloading is completed, double click the downloaded file to extract it.
"ZIP Self Decompression" appears. Click DECOMPRESS.
"The decompression process was successful." will appear. Click OK.
A folder will be created in the temporary folder created in Step 1.
Open the folder and double click DelInf32.exe. "Brother MFC Uninstaller" dialog box will appear.
Select your model and click OK.
"Complete" will appear. Click OK.
Click here to download the latest "WHQL certified Printer Driver and Scanner Driver", and install it following the Install Instructions.
Or
Still Having Problem Then Go To Brother Printer Official Website :
When trying to scan using the Brother ControlCenter3 on Wind Brother
Or
Stll Having Brother Printer Problem Then follow Us For On:
Brother Printer Support
Jan 20, 2014 | Brother Office Equipment & Supplies
How to remove black square from the screen without the original remote?
Usually need the original remote--if you can with buttons (not likely on JVC) try to set it to CC4 which is almost never active and should remove the text box that you are seeing.
Note: if using a cable or sat box look there also as most have the text feature also.
Apr 26, 2012 | JVC Televison & Video
What does the error cc4-205-00000000 mean
I have same problem when I tried to save file to google drive, then I change it and save to my desktop, it's working fine. I guess that is google drive's problem, I even tried to save to Dropbox, it is OK!
Mar 18, 2012 | Office Equipment & Supplies
Closed caption is on the screen and i can't remove it.
On your TV Remote:
CAPTION Cycles through the Closed Caption:
?? Anlalog Closed Caption:CC1/CC2/
CC3/CC4/TT1/TT2/TT3/TT4/Off
?? Digital Closed Caption:Service1/
Service2/Service3/Service4/Service5/
Service6/Off
May 05, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Black box fills most of screen on certain channels
THE cc key on your remote control might of been pressed by accident and the close caption was enabled, to correct this all you need to do is press the cc key repeatedly untill the c.c. is turned off, the tv display will go through cc1, cc2, txt1 etc. untill you get to the part that says cc off.
Jan 31, 2010 | Element Electronics FLX3210 32 in. LCD TV
Have a black-out square appear on some channels especially FOX
GO INTO THE MENU AND TURN THE TEXT OFF. THIS IS ASSOCIATED WITH THE CLOSED CAPTION. CC1, CC2, CC3, CC4, T1, T2, T3, T4, OFF
Jan 22, 2009 | Broksonic TV
Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Nov 27, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
406 people viewed this question
Jerry Greenberg
Jerry Greenberg
