Question about Olympus Zuiko 70-300mm f/4-5.6 Digital ED Telephoto Zoom Lens for Select Cameras
Olympus 70-300mm autofocus
I have an Olympus E-620 and when I try and use the autofocus the lens just oscillates back and forth. Another family member has the same setup and I tried the lens on her camera and it did the same thing and her lens worked on my camera so I know there is a problem with my len. Any suggestions? Thanks
  • Dennis Lucker Oct 27, 2012
    Thanks for the suggestions, having worked on several lens over the years I decided I would try this one. After looking at the a little closer I discovered a crack on the housing. So I think I will send it off so the part can be replaced. Once again thanks to all.
SOURCE: lens cover wont move
You probably didn't wash the camera after using it underwater specially in salt water. The salt will dry inside the lens and may cause this problem. Try soaking the camera for a while - wash it according to the manual's instructions. Hopefully soaking it will clear the deposits and clear the lens. Good Luck.
Posted on Jul 26, 2007
t00nz
  • 4738 Answers
SOURCE: olympus fe170 lens stuck
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE: Cannot auto focus?
This happened to me as well. Fixed it easily, once I balled up and took apart the lens.
bike guy is right on the money. The linkage between the autofocus motor and the lens assembly has popped out.
Luckily, this repair does not require and parts. The linkage just slides back together.
Take apart the lens starting from the back. After removing enough parts you should be able to see down into the lens and at the lens assembly that moves when you zoom. There should also be a ring that, has 5 contacts facing up, and if you move it turn the AF motor.
You should see the linkage coming off this ring and should see where it should sit. If the problem is this linkage (which looks like a bar extending towards the front of the lens), it won't be seated properly. Use a small screwdriver to pop it back in.
This repair requires a bit of handiness, but mostly it's just taking out small screws, being patient, and putting it back together. I'm not going to put instructions, because if you're going to take apart a lens, you should know your way around electronics.
Posted on Aug 21, 2008
SOURCE: olympus 710 lens won't open
I found tilting my camer downwards towards the floor and removing the usb cover and then turning the camera on worked, I am unsure if its a faulty motor or slightly damaged lens but once it's retracted the camera works fine - this was a test I was able to repeatedly do.
Opening the camera did not display any visible faults although with the housing off it did operate better. this will unfortunatly remove some the cameras weather proofing in the way opening a splash resistant watch will mean it no longer can be used near to water, this is due to the fact these cameras are factory made, also you risk dust getting in.
I have picked up another Olympus with the same fault on eBay it would appear the 760 model also suffers from this same problem
Geoff
Posted on Dec 17, 2008
  • 919 Answers
SOURCE: Olympus Zuiko 70-300mm lens focus question
Solved
Posted on Mar 16, 2009
Does not autofocus
Assuming you've made sure the auto-focus is turned on on both the lens and the camera, remove the lens, turn off the camera. Remove the battery. Wait about a minute. Put the lens back on, turn the camera back on . It's a computer basically. Sometimes it crashes. I've had this happen to me a few times.
Mar 13, 2012 | Nikon D90 Digital Camera with 18-105mm...
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
Canon 7D -I have my setting on one shot - in any mode.- Lens: Canon 17-85mm. The autofocus jumps back and forth no matter where I focus at.
it means the lens is about to die.
i get same problem with my nikon 18-55 mm lens. the solution for my problem was that i shift from autofocus to manual focus on the llens and then back to autofucus. the lens works fine for me then :P
u can try the same thing.
Mar 02, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Dear FixYa, I got an Olympus E-620 camera. Recently a friend of mine who owned an old SIGMA AF lens ( w/ Olympus mount ) wanted to release/sell it to me. Could this lens attached to my camera with or...
As an Olympus user myself, I would not advise even if you could find an adapter. Your 620 is a 4/3 series camera with is a different frame size than the old 35mm equipment which means you will not get ideal photo quality. Yea, new lens are expensive, but losing good shots to sub par equipment costs you more in the long run in frustration.
Dec 27, 2010 | Olympus ED 35-100 f/2.0 AF ZUIKO DIGITAL...
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
I can't get the autofocus to work on my new EF 75-300mm
I don't mean to insult your intelligence. You did check the Manual/ Autofocus switch on the side of the lens, yes? Maybe move it back and forth a couple times?
Is there a Macro switch on the lens? If so, adjust the lens-by hand- to where it lets you set the switch back to normal 75-300. You may have to zoom it out to 300 before you can slide that off Macro.
Try shutting down the camera and then back on ?
Remove lens and reinstall it?
Compare the electrical contacts on the lens to your other Canon lenses?
It could just be that one in 10,000 that is defective outa the box.
lightspiritphotography.com
Dec 25, 2009 | Canon 75-300mm f/4-5.6 III USM EF Lens
Won't autofocus
First try another lens on the body and see if the problem is the lens or the body,if its the body the autofocus mirror could be out of adjustment, if its the lens, it sounds like the lens took an impact and needs a pro repair. you should be able to set body to manual focus and focus lens to infinty.
Jun 11, 2007 | Nikon D50 Digital Camera
Olympus Zuiko 70-300mm f/4-5.6 Digital ED Telephoto Zoom Lens for Select  Cameras Logo
51 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
