Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
    Scholar:
  • 106 Answers
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
Posted on Oct 26, 2012
Motherboard vgn
Which is what?
No display on internal monitor of laptop?
Squiggly lines or pink screen, or vertical or horizontal lines?
What is the problem?
Also is it a Sony VAIO PCG-K23 Notebook PC?
Post back in a Comment.
Regards,
joecoolvette
Apr 30, 2013 | Sony VAIO PCG-K23 Notebook
How do i get rid of the horizontal and vertical lines on a sony prs 600? the unit was never dropped or mishandled. they actaull appeared as i was reading my book on it
Hi mdill9759,
Looks like a problem with the screen itself. Try this to see fi you can get issue resolved, good luck:
1. Hit the "Reset" button at the bottom of the reader
2. Slide the power switch, at this point the screen should blink and show "Opening book"
3. Allow the reader to load and see if the lines still appear on the screen
If the lines are still on the screen, contact Sony to get it repaired.
eBookBoy
http://digialreader.freeforums.org
Jun 12, 2011 | Sony Reader Touch PRS-600
I cant see the bottom part of my pc coz its distorted. Then my screen usually blinks or with some disruptions although the program is not affected. Then there is a noise inside my pc's body everytime i run...
Dear Valued Sony VAIO customers,
Sony has identified a limited number of VGN-CS series computers which may display a horizontal line on the LCD screen.
Applicable Models
  • VGN-CS1xx series
  • VGN-CS2xx series
  • VGN-CS3xx series
Resolution
As part of our commitment to quality, for an additional 24 months beyond the standard limited warranty period, owners of an affected model displaying the symptom may be eligible to receive service for the LCD screen from Sony free of charge.
If you are currently experiencing this issue, please contact us at 1-888-476-6972 to arrange service.
Dec 03, 2010 | Sony VAIO VGN-CS215J/W Notebook
I have a sony vaio CS series , Flickiring screen
try to restart in safe mode by tapping f8 while restarting the computer
Select safe mode and select "safe mode"
Jul 29, 2010 | Sony VAIO VGN-CS118E/P NoteBook
I have a sony vaio CS series , its a year old and the screen recently started to flicker, lines across the screen appears in a blink and goes every 5 seconds , Is there any solution to that problem and a...
You have a bad NVIDIA IC. You can go to sony US for the free repair of your laptop. Don't worry I already talk to sony's service assistant and told me it is free.
My sony vaio screen has some weird lines down the toolbar... everytime they're more, they're almost half the bar and it looks like it has some kind of problem
Try the below link...
Click here for more information
Jan 20, 2010 | Sony VAIO VGN-CS320J Notebook
VAIO - blinking line at the bottom of the screen
MY VAIO TOO! there's a blinking WHITE LINE at the bottom. i just noticed.. my vaio's just months old.
Dec 15, 2009 | Sony Computers & Internet
White horizontal lines appear in the screen
you may just need to reseat the cables. basically all you have to do is take the keyboard bezel off of the laptop and disconnect and reconnect the cables on the lcd. you usually do not need to unscrew anything but a pick would help. Just simply pry it off using a pick or small flatheadd80ef8a.jpg
Dec 08, 2009 | Sony VAIO VGN-CR220E/W Notebook
Horizontal lines
I am a laptop/PC technician and this problem is probably being caused by either a loose or damaged screen cable inside the laptop, a faulty or overheating graphics card or an incorrect graphics driver.
Unfortunately without actually seeing it I can't say which it is, but I would first off get a PC or laptop specialist to check to see if the graphics card driver software is correct, as this is easy and quick to sort out if this is your problem.
If this isn't the problem then I would just backup all your documents/files and return the laptop to Sony under warranty as a hardware fault could be expensive to repair.
I hope this helps.
Jan 02, 2009 | Sony VAIO VGN-CR220E/P Notebook
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
