Question about Lincoln Ranger 8 8000 Watt Kohler Gas Engine Driven Welder/generator Job Ready
My lincoln ranger 8 won't idle up when I strike an arc, but if i put it on high idle it will weld fine. I have replaced the PC board and accomplished nothing. $350 later I'm in the same boat.
  • 5 Answers
SOURCE: auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Posted on May 03, 2009
mamicheddy
  • 79 Answers
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
Posted on May 07, 2009
  • 518 Answers
SOURCE: my lincoln ranger 250 no weld output
sounds like the transformer winddings which generate the amperage for the arc are breaking down
Posted on Jul 07, 2010
ROMOAS
  • 97 Answers
SOURCE: Welding in TIG mode. Weld for 10 minutes, stop
the unit will need to go in for service there is a control bord issue there 4 in the unit these boards have to be tested by Lincoln i have the same welder and what they will do is swap out the boards till the bad one found if the unit is not under warranty they can be expensive mine coast 500.00 for the 1 control board there is not a clear way to say it is a particular one do to there all inter linked as to functions. go to the web site and search for a service center in your area hope this helps
Posted on Aug 31, 2010
SOURCE: HAVE A LINCOLN ARC 5000
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Posted on Nov 15, 2010
Why will it not rev up
Welder Idles but dosnt rev up so when i strike an Arc [Archive ...
www.hobartwelders.com > ... > EQUIPMENT TALK > Generator/Welders
Apr 21, 2008 - 7 posts - ‎4 authors
... is good there,I have continuity from the wire there back to the Auto Idle Module,and i... If it does not affect the idle. then check these things. ... out,,can i put a PTO cable on the throttle and pull up the RPMs when i weld? right ... Benefits of Stick?
Sep 26, 2007
SA 250 will not strike an arc
May 7, 2006
Lincoln Weld-Pak 100hd.. Need some opinions, =]
Jan 15, 2005
Aluminum repair
Mar 19, 2003
More results from www.hobartwelders.com
SA-200 Idler Troubleshooting - Weldmart Online
https://www.weldmart.com/main/.../sa200idler_troubleshooting.html
The solenoid pulls the carburetor throttle plate closed and the engine drops to idle ...Turn it off (close it) and the solenoid releases; the welder idles up. ... If it does show power-with the engine off, remove the wire and recheck the terminal. ... B. The idler solenoid is good but it will not idle up when you strike an arc, or when a ...
Idler control for sa 200 lincoln welder - American Welding Society
Dec 08, 2015 | Welding Tools
My lincoln ranger 8 has excessive weld spatter compared and the auto idle dosent kick in very fast when I strike off to weld delayed or sticks my rod. My other ranger 8 no issue same heats. Also
weld current and idle control on this machine is controlled by the main circuit board, you mention that you a second ranger 8 that does not exhibit the same problem, you are fortunate in this, remove the board from the functioning machine, install it into the troubled machine, this should correct your problem, you can contact a weld supply store to purchase a replacement pc board
May 27, 2015 | Lincoln Welding Tools
Welding rod sticking when striking arc
try striking the rod like a match. keep a good arc, not too long or short. try around 90 amps.
Apr 28, 2013 | Lincoln Electric K1170 AC-225 Stick Welder
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Jul 02, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
301 wont high idle when striking arc
There is a small electronic control board inside the welder that senses current flow and pulls up throttle. It could be the board has a problem, or the throttle solenoid itself. You'll have to do a bit of checking.Check for loose connections or blackened components on the control board.
Jul 03, 2009 | Welding Tools
My lincoln welder/generator Ranger 8 will not idle up when stricking an arc, it will idle up if I plug in a drop light.
May 07, 2009 | Lincoln Welding Tools
Auto high idle lincoln ranger 8
Apr 29, 2009 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
Lincoln Ranger 8 8000 Watt Kohler Gas Engine Driven Welder/generator Job Ready Logo
559 people viewed this question
Top Lincoln Electrical Supplies Experts
 Kenneth
Kenneth
John Trevino
Jay Finke
Jay Finke
Are you a Lincoln Electrical Supply Expert? Answer questions, earn points and help others
