Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Hi, I was trying to fix a contact issue with the bulb on my Liftmaster Chamberlain garage door opener when there was apparently a short circuit, something blew and the switch at my house power supply box got tripped. I could see a little bit of smoke after the event. I looked at the parts after taking the metal enclosure off but it isn't apparent to me what blew up. I am guessing it was a fuse but am not sure where the fuse(s) are located. Can you advise where I might find the fuses for the Chamberlain garage door opener (model 1045-6), or any other usefull advice?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
There is no fuse. You damaged you logic board around $90 for the part. sounds like you have other issuses with your operator if contact issue on your bulb. You might consider replacing your operator.
Posted on Jan 03, 2009
Are bulbs for garage door openers special
most openers house and medium based bulb (regular type)
and the bulb physical size is normal, but some have to have short necked bulb due to confined space. usually are 40 or 60 watt.
Oct 13, 2014 | Sears Craftsman LiftMaster Chamberlain...
The lights on my Liftmaster no longer come on. Tries all new bulbs, but still no light.
Unplug the opener and remove the bulb. Using a small screwdriver pry out on the center contact of the socket. Replace the bulb and plug in the opener.
Feb 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I had a LiftMaster model 2000SDR. remote won't work when light is still on. Only wall control can operate garage door. Once lift is off, then remote control work. How to fix this problem?
Remove the bulb and try. The bulb or the socket may be radiating a signal. Unplug the opener and pull out on the center contact of the light socket. Try another bulb.
Feb 06, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener works fine. But the lights are not working. Changed light bulbs,Light bulbs are good, I have checked. tried bending the copper tabs in bulb socket out a bit. Still not working. ...
Make sure you are using standard 60 watt bulbs. Some newer type bulbs are causing a problem. If you have a multimeter and are handy it should be no problem to check for 110 volts at the socket and trace the wiring back to the circuit board. There may be burnt or missing traces on the board itself. The click you hear is the relay that controls the lights so you know that is working but there is always the possibility the points are bad.
Jan 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 hp professional, all functions work except for lights, i have unplugged and replugged in, bulbs are new, contacts good. Any suggestions?
Unplug the opener and remove the bulb. Using a small screwdriver pull out on the center contact in the socket. Replace the bulb and plug in the opener.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
The light on my Chamberlain garage door opener does not work. I replaced the fixture that the bulb screws into but it still does not work.
Try unplugging the opener, removing the bulb and pulling out on the center contact in the socket with a small screwdriver.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs constantly burn out in Chamberlain Garage Door Opener
Unplug the unit from the power and take a screwdriver and pull out on the center contact of the socket.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Opener Lights will not come on
IF YOU CAN - TEST FOR 110V AT THE CENTER TANG OF THE LIGHT SOCKET.
IF NO POWER YOU PROBABLY HAVE A BAD TIMER CIRCUIT ON THE BOARD - NO EASY FIX NEW BOARD.
IF YOU HAVE POWER YOU MAY HAVE ISSUES WITH THE SOCKET OR ARE USING THE WRONG BULB - A STANDARD LIGHT BULB IS ALL THAT IS REQUIRED. SOME OF THE NEW BULBS HAVE A SIMILAR LOOK BUT DO NOT WORK IN A STANDARD SOCKET.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
294 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
