Question about GE GSH22JFR Side by Side Refrigerator
I have a GE Refrigerator with a built-in door handle, TFX22ZPBA
How can I fix it? After a while, it looks like one of those days I will pull de door a keep the hadle in my hand. Could you help me?
  • Anonymous Jan 10, 2009
    My GE door handle is almost off. I'm not sure what to do. Any suggestions?
  • 29 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
  • 833 Answers
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
SOURCE: GE Side by Side refrigerator door handles yellowing
I have tried everything to clean these handles. This refrigerator was a piece of junk from the onset. The fan on the ice maker has had to be replaced twice and the motor once. The ice maker has always leaked and frozen. This was extremely disappointing and I will not be buying GE products again!
Posted on Apr 05, 2008
SOURCE: Ge profile refrigerator door handle is loose
On the GE Profile, the handle is mounted to two small screws. To detach the plastic housing, you must press on the two connection points (the base and top of the handles) and slide the handle up or down (takes some effort). The handle will come off and you will have very easy access to these 10mm screws.
Posted on Apr 09, 2008
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
GE Energy Star French Door Bottom Freezer handle popped off
You cant find a hole to insert screw from outside. It is true, and you can't fix it yourself to what it looked like earlier. The company first screws in through the handle and then covers the hole made by it with the material of the handle. If you have to fix it yourself, you can only pierce those screws through the handle leaving the mark behind. If you don't want that, contact your company or dealer.
Apr 22, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Nov 07, 2008 | GE Refrigerators
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Freezer door handle loose
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE refrigerator door problem (model TBX25PAYARWW)
Is sounds like you will have a broken or worn out or bent hinge. It may be a combination of the 3.
Dec 26, 2007 | GE Americana 15.6 Cu. Ft. Top-Freezer...
GE GSH22JFR Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
