Question about Sony Walkman D-EJ1000 Personal CD Player
The re-chargable batteries wouldn't stay charged,so I bought new ones ($45.00)but realized it has to stay in the electric charger base, I believe the button is broken. Where do I send to be repair
When you sit in plugged in base to charge the batteries the light doesn't stay lit, after overnite I figured the batteries should be charged but the CD player wouldn't play once you took it out of the battery charger stand. I believe the charging button is damaged and its old but plays great. Where would I take it to see if it could be repaired? Thank you, Dotti Murray
  • 473 Answers
SOURCE: Can a lithium ion battery be overcharged?
Here's a small FAQ I found: 1) My lithium ion battery is the SONY NP-FP70 Battery Pack. Does the fact that the battery is called a battery pack mean that it has built in circuitry to prevent an overcharge? No. I write with some authority since I've dissected too many and there is no such circuit in the battery. From a system perspective it doesn't belong there. 2) Is there any way of knowing if my SONY BC-TRP charger has the circuitry for preventing an overcharge? You'll have to ask, but the key clues are: a. The documention tells you to not leave it plugged in overnight. b. The battery gets too hot and melts the plastic. 3) If I charge my battery in my camcorder (SONY DCR-HC40), can I assume it has the built in circuitry to prevent an overcharge? a. One can't assume anything. b. But from what I read on that model, you plug it in and forget about it. To do that, it would have a proper charge circuit.
Posted on Sep 13, 2005
SOURCE: new batteries will not charge
a technician ' s adjustable bench power supply - set for 9 volts at 1 amp - for a minute or so , will initialize most new lithium batteries ( a charger update may also be available ) ;
Posted on Jul 31, 2007
beergut707
  • 79 Answers
SOURCE: initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Posted on Oct 09, 2008
SOURCE: Sony cybershot f717 battery won't charge
Same for me too... And a bunch of other stuff! I can't choose to have the flash, can't use the veiwfinder...
Posted on Oct 31, 2008
welcomejee
  • 10594 Answers
SOURCE: do i need a special charger for the NE-720 internal battery
It needs AC-ES3010K2 ac charger to charge battery.
Click HERE and download user manual of Sony D-NE720 for further details.
Posted on Feb 08, 2009
My PS3 headset won't charge it stays lit for 3
If there was no change using a new charger, I would suspect the battery is shot
Apr 23, 2013 | Radio Communications
Electrical problem on 1996 Dodge Dakota
It will drain at a rate of 21Watts X 2 = 42Watts at 12Volts = 3.5Amps. If you have an 70 Ah battery that is 20hours to totally flat from fully charged.
May 27, 2017 | 1996 Dodge Dakota
I bought a Syma S107 and have enjoyed flying it immensely. I would plug it in to keep it fresh, recharged, and ready-to-fly. Recently, I found that it suddenly wouldn't climb more than an inch high...
Li/Po batteries are meant to be stored charged, so that shouldn't be an issue. Were you leaving it plugged into the charger? This is not the best idea. Not only will it likely slowly sap the battery's ability to hold a charge, if, by some freak happenstance, both the PCB (overcharge protection) in the battery and the one in the charger were to both fail...
POW!
More common than anything I've come across regarding battery death is proper care. These small, lightweight, high output Li/Po batteries NEED to be cooled for 10 minutes after flight, and ALSO after charging. And most important, never drain them completely. As soon as your helicopter cannot maintain altitude, land and power it off. Cool 10, charge until fully charged, (light on charger at it's brightest) cool another 10, fly. Rinse and repeat.
Note: the batteries on the s107 are tricky to replace, micro soldering is required. Sadly, unless you have soldering equipment and know-how you'll probably just have to but another one. If you do, look for the s107's with the pink and green motors, not the black and white ones. Amazon sells the pink/green ones, and is the only place I've found them, look for the ones with "Amazon Inc" as the vendor, and check the pictures. The black/white ones are fine, (I have 3) great even. The pink/green and faster, lighter, far more agile, and are good for a minute or two more flight time based on my experience.
Good Luck, and I hope this helps,
PvT
Sep 11, 2011 | SYMA Toys industrial New Syma S107 Mini...
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
I have had 4 pantech jest phones and it wont charge!!!! i had it plugged in then i thought it was charged fully cause the bars were full when i took it out.....BAM!!!! i shutt of!! im sick of it i had 4...
Make sure you're using the Pantech charger you got with your phone. I had this problem, got a new one, and realized I'd been using my old charger charger. Plugged it in with the wrong charger, it wouldn't work. Plugged it in with the Pantech charger, it started charging up and worked fine again.
Dec 27, 2010 | Cell Phones
Razor e300 scooter charger light stays green, batterys not taking a charge. I can hear a click when turning on throtle. battery or module?
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Aug 16, 2010 | Razor E300 Scooter
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
Charging batteries
the cobras are meant to work with alkaline cells. You bought nicads which are a lower voltage per cell (1.2 to 1.38). Alkalines are about 1.55-1.58
That is why your rechargeables only show a quarter charge, because their terminal voltage is lower and the radio thinks they are not fully-charged.
May 28, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Sony Walkman D-EJ1000 Personal CD Player Logo
32 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
