Question about Sansui Televison & Video
I can hear my vhs, but not see it. I have no problem with my other VHS'. How do I fix the tape?
I don't understand? I know it's the tape, but how to I fix it? I wanna watch it, not just hear it.
Try a different tape. If it do the same probably your VHS video head is dead. The audio and video uses a different head.
Posted on Oct 26, 2012
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
My VCR eats tapes after a few minutes.. does it just need to be cleaned?
Sorry,no the VCR mechanical systems pully is out wax.Not worth fixing because the VCR technology it in the past or probabally have no more parts for analonge tv or produced by the tv manufacture anymore.If u vaule ur VHS tapes,just don't used the VHS tapes in this machine.
May 13, 2011 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
I video taped a wedding and am trying to copy from my camcorder "VHSC" to VHS RECORDER - PROBLEM IS I AM GETTING AUDIO BUT NO VIDEO when i try to replay from vhs tape on VCR
I can only believe that you did not connect everything (the yellow video cable) correctly.
Tape to tape copies are normal and typical. Please consider retrying - and just do a few minutes of test video to confirm that it is working.
If you were doing a digital translation, I could understand a problem - but VHS to VHS should be a straight copy.....
Let us know how the test works. (BTW, I had a bad quality video cable - and had to replace it with another - which worked (and everything would display on my TV but would not copy onto another tape. My expert said that a copy protection thing in the record mode of the VHS recorder was the issue - ONLY a strong signal will be copied.
Oct 14, 2009 | Quasar VM-L153 VHS-C Camcorder
Symphonic vhs tv turns off i hear the vcr after that it turns off
The vcr sistem is out of time and the microprocessor don´t detect the tape is out,you need to change the motor belt charge,good luck
Mar 16, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
VHS code compatibility
The video standard in Japan is PAL while it is NTSC here in the USA. You should be able to locate a VCR than can play both. If you'd rather not purchase a new VCR, some locations that create DVDs from VHS tapes can usually also read PAL tapes.
Dan
Mar 18, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
