It doesn't want to print ,copy , or scan , it does have ink
  • Scott Newman Oct 26, 2012
    When you say it has ink, are these new cartridges?  Are they authentic HP cartridges or no name ones or have you gone to a place that refills them?
  • 14,417 Answers
  • 14 Answers
SOURCE: There are verticle lines when faxing, copying, and scanning.
This print defect can be caused by a foreign object or substance on the outside of the scanner assembly, usually located on the plastic cover that the paper passes over.
Posted on Feb 04, 2009
  • 295 Answers
SOURCE: My printer prints and copies but doesn,t scan
scanning requires a place to keep a copy of the document.connect ur computer and printer via usb2.0 and then open kodak home center from ur desktop. from there scan the document. u will be able to scan and keep a copy of the document on the desktop. if there is any problem,contact kodak @ 1800 421 6699
Posted on Jul 21, 2009
SOURCE: I have a Ink System Failure.
I had this same problem but with a different error code. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Posted on Sep 08, 2009
SOURCE: My canon MP40 will not scan/copy
This is because you have NOT installed the actual Drivers for the scanner and the Scan Manager. Driver link below. Ensure you get entire package A:SO get the user manual, it shows you what to do.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
Posted on May 14, 2010
  • 96 Answers
SOURCE: replaced ink cartridges now cannot print with
Drive belt is broken or has holes in it and cannot move past switch that dumps ink. Replace drive belt. Go on Kodak.com to order part
Posted on May 28, 2010
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Hello, my printer is able to scan and copy but it doesn't print. Both the cartridge lights are blinking but their is sufficient ink the cartridge. Can you help? I have Cannon MP190. Thanks
If the lights are blinking for the cartridges, then there is not enough ink.
Get new ones or refilled ones and try it again.
Or there may be enough ink, but the electronics on the carts are not working, could be a short, or an open circuit.
May 26, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Will the printer scan or copy if the ink is dry?
The printer will san to screen but not to a copy. No ink, no copy
Feb 11, 2011 | Lexmark X73 All-In-One InkJet Printer
I want to scan but it doesn't let le scan or copy anything, It says that my colour ink has finished but does that mean it doesn't let me even scan or copy, beacuase it has nothing to do with printing. Is...
It should let you scan, but you cant copy, if the ink is empty.
Probably just a scam so you cant use the device with no inks.
If you go to the control panel, you may be able to use the scanner from there. You may just have to replace the inks.
Seems a rip off to me.
Sep 04, 2010 | Office Equipment & Supplies
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Canon mp 145 scan not working ink catridge empty... scan wont work without ink catridge?
Hi, The scanning unit is independent from printing unit. You can scan even with empty ink cartridges. At sametime, if you wanna copy documents, you need both scanning and copying units to work. Try reinstalling the Driver from the provided drive CD.
Feb 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
The waste ink absorber is almost full will not print
wait until the absorber counter full and reset it with this instructions
Mar 25, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Red ink run out, can`t scan
you can refill the caterage which will be cheaper for you
Dec 07, 2008 | Canon PIXMA MP510 All-In-One InkJet...
20 people viewed this question
k24674
jasbo
jasbo
