Question about Samsung YP-T8 Digital Media Player
Samsung yp t9
I was downloading a file when my computer alterted me that an error had occurred. I went to disconnect my MP3 from the USB and not its frozen ='( What should I do?
Firstly, "re-set" the T9 (ie hold 'MENU' & "REC', for 3 secs to re-initialise the built-in firmware - refer to your manual, or download manual off Samsung website). This procedure will overide everything. If this gets it goin, then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your T8 - your manual should explain how to do this. Always update your T9 with latest firmware when available (appropriate with your Windows OS), to eliminate any bugs in the firmware. Failing this, then a replacement battery is the next step. If still under warranty (ie less than 12mnths old), then have an approved Samsung service agent look at it Free of charge. Good luck.
Posted on Jul 01, 2007
How do you put videos into the YP-T9 mp3 using windows media player??? Would I have to convert the videos somehow? I've been having trouble with this, please help!
Look sir.The yp-t9 can only play svi files.In order to put the videos into your yp-t9 you must hav samsung media studio and also the videos must be in either mp4,avi or wmv format.And then use Samsung media studio to put the videos into your yp-t9,samsung medai studio will convert the videos into svi format which your yp-t9 can read.
Feb 21, 2009 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 problem
look buddy first u shud get rid of the shorting out on the usb connection.
then get to samsung.com and check the support page of ur product and start downloading!!
Jan 07, 2009 | Samsung Yepp YP-T9 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Videos
Yp-t9 only plays svi files.First make sure the videos you have are mp4 or avi or wmv.Then open samsung media studio.If u dont have it then download it.After that put the videos in your yp-t9 using the samsung media studio.The samsung media studio should convert those files into svi format which can be read by your yp-t9
Oct 09, 2008 | Samsung Yepp YP-T9 Digital Media Player
Help i have a Samsung YP-T9 and it froze
hold down the menu and play button at the same time to reset, should turn it off, then just turn it back on again
Jun 11, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung Yepp YP-T9 Digital-video playback
Yp-t9 can only play svi files.First convert those mp4 files into avi or wmv files.And use samsung media studio to put them into your yp-t9.The samsung media studio will convert ai and wmv files to svi.Or jus try to convert those mp4 files with Samsung media studio.It converts sometimes.
Jun 07, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 corrupt files
Go to the settings menu in your yp-t9.Then open the system menu.Then update the library.The files will go after this.Guess this helps.
Jan 18, 2008 | Samsung YP-T8 Digital Media Player
Video Upload problem
Yes u can say that.The files can be of avi or wmv format.After that use Samsung media studio to put these files into your yp-t9.The samsung media studio shoul convert these formats into svi format which can be played by the yp-t9
Sep 27, 2007 | Samsung YP-T8 Digital Media Player
Samsung YP-T8 Digital Media Player Logo
117 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
