Question about Line 6 DL4 Delay Modeler Effects Guitar
Line 6 how do i get it to work
How to make it work,i have it plugged in but no effects
    Novelist:
    Champion:
  • 225 Answers
Line 6 connected to AC power and LED showing power to unit. Guitar into effect input, effect output to guitar amp. Does guitar make sound through amp in bypass mode? No then check cables...yes then use foot switch to turn Line 6 effects unit on. Adjust control knobs for desired effect levels/settings.
If pedal provides no effects...off/on switch defective or internal electronics in need of repair.
Posted on Nov 01, 2012
Why is channel 1 clean/green not allowing my effects pedals to be heard? Only straight clean is audible. On all other channels they are present. Has anyone had this same issue? If so, is there a solution?...
Frankly, I've never heard of this problem and I've used Line 6 gear for years. I suggest contacting Line 6 customer support. Here is a link to their contact page
Line 6 Support
Mar 02, 2015 | Music
How can i tell which version my m13 is. just bought it new
The easiest way is to call Line 6 at (818) 575-3600 and press 2 for Service. You will find getting info from them much easier if you register your new product with them.
Oct 22, 2014 | Line 6 M13 Stompbox Modeler Multi Effect...
Heating when powering on?
Be sure you are using the correct voltage power supply for your area. If so, it's likely you have an internal power supply part failing. Best take it to an authourized Line 6 repair center or return it to the factory for repair.
Aug 18, 2014 | Line 6 Line6 Podxt Guitar Effects...
How come mmt tweak knob and select knob arent working on my line 6 pod xt live
It sounds like the pots need replacing if re-soldering didn't work. i would take it to a Line 6 authorized service center.
Line 6
Sep 01, 2017 | Line 6 New Line 6 Pod Xt Podxt Live...
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
Feb 06, 2012 | Soundcraft Efx12 12-channel Mixer With...
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
I purchased a Line 6 amp about 3 yrs. ago and has barely been used. I went to use the tuner and it would not work along with the B channel also doesn't work. Could someone give me an answers as to why...
I suspect that switch contacts are to blame... often the very weak contacts on jacks that are for inserting effects, for example, get oxides on the contacts that forward the signal from the preamp to the power amp block the signal. The quality of many of the jacks used on these amps is really poor.
Jan 06, 2011 | Line 6 Spider Iii 120 Stereo Guitar Combo...
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Jan 23, 2010 | Line 6 Spider Iii 30
I don't know....
As you know, when you plug in your headphones, the amplifier cuts the sound to the external speaker, routing the signal through your headphones instead.
When you accidentally pulled the headphone plug from the jack, it apparently damaged the jack, which has the relay attached that routes the sound to your headphones.
Replace the jack, and everything may be OK. I say may be, because the jack is attached to a circuit board in these line 6 ampllifiers, and if you have damaged the circuit board, you will have to send it to line 6 to be repaired.
The downside is if it is not under warranty, it is an out of pocket expense, and Line 6 will not even give an approximation on how much a fix will cost. I have gone through it with Line 6 in the past, so I am very aware of the procedure. It is also a limited warranty, and they may not cover this particular damage.
However, if you are straight with them and they feel obliging, they may fix it under the warranty, if it is still active on your amp.
I had a spider 2 x 12, which was switching between amp models by itself, and they told me that because it was not under warranty, that I might want to consider NOT sending it to them, and just buying another amp. I didn't like that advice, because they seemed as though they didn't care about retaining my business.
Now, something to consider is taking it to a reputable amp repair shop (preferably one that is Line 6 authorized), and see what they can do. Maybe your clip is just bent, not allowing it to spring back from the contact switch that cuts off the main speaker. It could be a very inexpensive fix, but you need to have a shop actually take a look at it up close and personal.
Good luck. I, for the most part, enjoy Line 6 products, and their excellent distortions. Just remember, their amps tend to have a LOT of problems. You can find sites that list many many dissatisfied Line 6 amp owners. All that electronics (on board effects, soft buttons and switches, etc.,) make them vulnerable.
Now I mainly use my old reliable Marshall 1/2 stack with my Line 6 pod, as well as quite a few other pedals.
You would be amazed by the fact that you can still get pretty good money for a broken line 6 amp, maybe get something with less bells and whistles to break, and go with off-board effects pedals and processors.
Please excuse me for adding my own opinions, I am quite well versed in this type of advice having grown up in a luthier / guitar shop and have been playing for 38 years.
Good luck with everything, and if all goes right, adn it is just bent, it may cost you as little as a few dollars to fix. I'll keep my fingers crossed for you.
Thank you for using FixYa.
Sep 09, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Line 6 DL4 Delay Modeler Effects Guitar Logo
165 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
