Question about Altec Lansing Audio Players & Recorders
My Altec Lansing VS500 subwoofer makes a strange thumping sound.
My subwoofer makes a thumping sounds when it is turned on. How do I fix this?
  • 205 Answers
SOURCE: Altec Lansing VS4121 no sound
If removing and reinstalling the driver fixed your problem then there was nothing wrong with the speakes. There was probably a problem with your soundcard drivers.
That being said, you should double check that you speakers are plugged in to the right sound board connector and the power supply is plugged into the wall outlet.
Does you computer have a headphone jack? If it does, you might try plugging a headset into it to see if you can hear sound there. If you do then you'll know the soundboard is working properly and maybe the speakers really are part of the problem. CD/DVD drives usually have a headset jack, but this will only work if a cable was run inside the computer from the CD/DVD drive to either the soundboard or motherboard.
What kind of computer do you have? Do you know if you have on board sound or a seperate sound board?
Posted on Nov 19, 2007
totonf
  • 35 Answers
SOURCE: Speakers
First you may try speakers with another device (like a mp3 player), does it works?
Posted on Jun 22, 2008
SOURCE: cannot connect my surround sound altec lansing system to my compu
The first thing you can do is go to www.retrevo.com to download the manual. Secondly all you have to do is match the colors of the wires to the imports in the back. You have five speakers. Two have gray wires, two have red and one has blue. If you also notice each speaker has two wires. One a solid color, the other striped with black. For instance, put the solid red wire into the red import and the red wire with the black stripe into the black import. Repeat this with all the other wires. The easiest way to hook it up to your computer or laptop is to take one of the aux wires (the wires with the yellow/green/black tips). It doesn't matter which one. Put into you headphone import on your computer or laptop. Then put the other side into the Aux on the subwoofer. Located on the front. Turn on the power on the back. Then hit the aux button on the remote. That should work....
If you have any other questions or need any more help you can contact me brown.faith@rocketmail.com
Posted on Jan 26, 2009
Monster80
  • 463 Answers
SOURCE: pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
Posted on Apr 03, 2009
freetek
  • 5568 Answers
SOURCE: My subwoofer (Altec Lansing[AVS500]) is always makeing a thumping
You could only verify this by gaining access to the rear of the speaker but I suspect that the 'spider' has come unglued. This is a device that surrounds the lower (inner) end of the cone to provide a second point of suspension; without this, the voice coil can slap against the side or bottom of the magnet structure.
I don't think a repair is an economical choice for these; repairs only make sense for 'professional' speakers that cost several hundred dollars to replace.
Posted on Apr 13, 2009
Altec lansing t612 thumping noise
Your speaker is sensitive to subsonic transients produced by the amplifier driving it.
Jul 15, 2016 | Altec Lansing T612 - High End Speaker...
I need to figure out how to open up the subwoofer for the Altec Lansing vs2121 model. Thank you
theres no on/off button for the subwoofer. once you plugged in the power cable,turn on the speaker system by turning the VOLUME knob on the right satellite until you hear a click sound.
An LED will light on the front of the right satellite when the power is ON. if you still dont hear any sound from the sub woofer then check to make sure that all cables are connected properly and are making a clear connection.
hope this help
Sep 06, 2010 | Altec Lansing VS2121 Computer Speakers
Power cord makes a chirping sound and won't supply power to M602. Do I need to buy a new power cord and if so where?
My experience is that when AC adapters start making strange sounds, they're no longer usable (or at least reliable), and need to be replaced.
I'd suggest calling Altec Lansing to see where you can get a replacement power supply.
http://www.alteclansing.com/
Feb 02, 2010 | Altec Lansing M602 (021986953371) Docking...
Apr 13, 2009 | Altec Lansing 621 Computer Speakers
Continuous noise from speakers, not subwoofer
las cornetas se escuchas muy bajos, porq no tengo los drives instalados
Mar 16, 2009 | Altec Lansing VS2121 Computer Speakers
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is PartsExpress.com
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
Powered sub
thats sounds like feedback. try giving your sattelites spacings. if they are near to each other, try to put them far from each other.
try also to turn of your microphone. that might work.
Jan 14, 2008 | Altec Lansing VS3251 Speaker
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
WOOFER SOUNDING BAD ON CERTAIN BASS FREQUENCIES
Try a software solution- download an audie editor like Audacity. The fault sound like a malfunction in the speaker unit ,which is not servicable.
May 17, 2007 | Altec Lansing ATP 3W Computer Speakers
164 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
