Question about Kohler Home
How to remove a hard plastic Kohler toilet flapper ? there are hard plastic flange hooks which hold the flapper arms.
Kohler 84631 hard plastic flapper is attached to the tower with closed loops or holes in the arms the tower has plastic l hooks. the flap arms seem too strong to turn enough to go over the bend in the l hooks
5 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
jj505
  • 195 Answers
SOURCE: flapper on toilet hooks onto a plastic ?hook. one snapped off
Yes it is called the flapper and overflow houseing it will involve removeing from tank and is not and easy task, may want to try to by one that has a "hole in it to slip over the "overflow' and slide downto where you broke it.
Please rate. Thanks jj505
Posted on Mar 30, 2009
Malcg
  • 32 Answers
SOURCE: Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Posted on Aug 16, 2009
  • 3 Answers
SOURCE: my soft close toilet seat keeps falling off. It
Buy a new one, repair is not an efficient answer.
Posted on Oct 27, 2010
Tip
Kohler Toilet 1.6 Gallon Flush Install Tips. We just recently installed two of...
We just recently installed two of these and they work perfectly.
LESSONS LEARNED:
-This is a almost complete in box and needs to only install the tank and seat. It also came with a new wax ring and bolts.
-What you also need is Full ring flange repair kit, (this is a round metal ring that goes over the existing plastic flange on the floor), put in as many screws as you can. On both we broke the plastic flange while installing the bolts. also the second one we also added a washer on the back side of the metal flange repair ring this made the connection even stronger.
-The new bolts that hold the toilet to the floor will be to long and an need to be cut off. Don't just try to brake it off, we ran in to big trouble and is how we broke the flange.
-Lastly go ahead and use Tub sealant and put a bead around the floor and base of toilet, this will keep it more secure and not allow any fluids to seep under the toilet and start smelling.
Hope this tip helps.
R/
David
on Feb 15, 2010 | Plumbing
Kohler toilet.............flapper leaking, so replaced it............in trying for better seal, put gallon plastic bag around hand and tried to push down flapper for better seal......Whoosh.......lost...
Hi lip58122
Get a piece of wire a couple of feet long (straightened metal coat hanger) and make a small hook in the end, insert the wire hook into the flapper hole and turn the wire a few times in a circle...you are trying to wrap the bag around the hook, if sucessful you will be able to remove the plastic bag.
Please take time to rate me
Sep 06, 2011 | Kohler K-3451 Memoirs Comfort Height...
We have a san raphael one piece toilet, and it sounds like the water is running at intervals. Sounds like there is problem with water level. What can I do to correct this problem? John
Sounds like the flapper is leaking water out of the tank. The flapper is the rubber valve that comes up and down every time you pull the flush lever. It is located in the tank at the bottom in the center. Very cheap part to replace.. Just turn the water off to the stool, take the top of the tank off, hold the flush lever down until all the water is out of the tank, reach in to the tank, disconnect the flush chain from the flapper, and disconnect the flapper arms holding to the stem. You can buy a flapper at any hardware store even at wal mart. Hope this helps.
Jun 25, 2011 | Kohler - Toilet - One-piece - San Raphael...
How to disconnect flapper on kohler k3386DA
You just need to slide the arms of the flapper while rotating away and upwards off the bars; the arms are flexible so they pull away quite easily.
There are some illustrated installation instructions on the Kohler site that may be helpful.
Go to: http://helptopics.us.kohler.com/ics/support/default.asp?deptID=5712
On the left side menu click on Bathroom Fixtures; click on Toilets, click on next under the questions to move to question 18, How Do I Install the 84995 Flapper?
Mar 02, 2011 | Kohler K-3386-0 Rialto one-piece...
The toilet has been leaking slowly and it's trying to fill us every few mins, seems like the flapper or the seal is leaking. How do I know which one?
hold the flapper down and see if it stops leaking but it is almost positively the flapper. turn the water off, remove the old flapper, adjust the chain on the new flapper to the length of the old flapper, wipe the port area where the flapper seals to remove residue, install new flapper.
Dec 05, 2010 | Kohler K-11470-0 White Wellworth Complete...
I have a 2yr old Kohler 1.6 oblong toilet. Recently after flushing the water does not shut off. I have to take tank cover off and gently push down on the "guts"
Note: Before doing any major work on your toilet, be sure to turn off the water supply to the toilet...
If your toilet's "guts" have an float ball, try unscrewing the ball a little to lengthen the float (which controls the water shut off)
If that does not work, try putting a little bend in the arm that the float connects to get the ball lower into the tank.
If you are referring to the style float that surrounds the fill tube like a doughnut, most likely you have some sort of build up either on the fill tube the float surrounds, or on the float itself - or both - that is causing friction that not allowing the float to travel (and shut off the water fill into the tank
If you are referring to the flapper at the bottom of the tank that allows water to travel from the tank to the bowl, most likely it is has two "arms" that anchor to the flapper to the fill tube. There may be some buildup on these arms that needs to be removed to allow the flapper to open and close easily.
If the flapper is not closing, you may also have a chain that is binding up when the flush handle is pushed. Clean the chain with some CLR, and/or remove any excess links that are piling up when the flapper is closed.
Mar 06, 2010 | Kohler Cimarron Comfort Height elongated...
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
My toilet is a kohler low profile. There is not a
Hacked off the old seat? You mean the closet flange that connects to the sewer pipe?
That's the part that has the bolts. They go up through the toilet base.
If you have just a straight sewer pipe now, you can connect a new closet flange to it.
1.Hardware stores sell a rubber sleeve. This sleeve fits over the cast iron, or copper, or plastic PVC pipe, and the new closet flange has a stem that fits down in the sleeve. There are two large hose clamps, that come with this rubber sleeve.
The rubber sleeve is an adapter. It adapts the 4 inch sewer pipe, down to the 3 inch stem on the closet flange. (Toilets are known as a 'Water Closet', hence the flange that the toilet bolts to, is a 'Closet Flange')
Whatever size of rubber sleeve you need to adapt two pipes together, they have it.
The new closet flange is made of PVC plastic.
(Poly Vinyl Chloride)
The flange itself is about 1/2 inch thick, and has provisions for bolts. (Use Toilet Bolts, and nuts)
Be sure the closet flange sits flush to the floor. The 1/2 inch thick rim of the flange, sits on top of the floor. The flange is then screwed to the floor with countersink head screws. The slots allow the bolts to just slip in.
IF, the flange Does Not sit level on the floor, and the area for the toilet base is not level, you need to make a flat, level surface!
Do Not half step this, or you'll have a toilet leak from now until the time you fix the floor!
Would appreciate it if you would rate my solution. If you have additional questions, state them by clicking on Additional Comments.
Jul 17, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Home Logo
515 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
