Need CFM capacity for Adobeair Cooler ES143H - Heating & Cooling
3 Suggested Answers
Ed Phillips
  • 11 Answers
SOURCE: air coming out of an adobeair portable evap cooler isnt cold
paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
Posted on May 31, 2009
manhandy
  • 146 Answers
SOURCE: I have 550 CFM cooler and the air is blowing but
you need to open up and clean the pump unless gravity fed but still need to cleaned. or new pump.
Posted on Jul 13, 2009
ADOBEAIR MODEL # P400B NEED MEDIA PAD
I have a adobe air model rw 4500 need side to hold pad.
Jul 31, 2011 | AdobeAir Mobile Swamp Evaporative Air...
The unit in question is a Master Cool portable evap cooler model #P500A. Everything operates perfectly accept the fan blower unit when turn on. Switch panel lights up but no blower operation. Are their...
The bearing on the blower motor are probably rusted or stuck from winter storage but you can disassemble the cooler and try to re-grease the blower motor front main bearing to access the rear bearing you have to take apart the blower motor . i had the same problem with my two p500a models and they work perfect now . i couldn't find any replacement parts but if i do i'll post the web site here hope this helps you with your problem N0D0ZE
Jul 22, 2011 | AdobeAir Adobe Air 550 CFM Portable...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Jul 11, 2009 | AdobeAir Adobe Air 550 CFM Portable...
Remove the front and rear panels off of a MasterCool P12
Lift yhe panel and pull out at bottom. The ones that come out usually have hand slots
Jun 09, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Air coming out of an adobeair portable evap cooler isnt cold
paula298,
I hope that helps.
May 12, 2009 | AdobeAir Evaporative Cooler Direct Drive
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
