Question about Craftsman Garden
Idle rolling kohler engine 14.5 hp 38" deck rear bagger. When the mower is in full throttle, the engine (without the deck engaged) does not run steady. The idle rolls, going high and low like it is running out of gas. I tried carbuerator cleaner which didn't help.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 100 Answers
Are you talkin aboutit surgin up and downat high idel thats normal when you engage the blades it levels out under load
Posted on Oct 27, 2012
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 86 Answers
SOURCE: Hi,
Sounds like electronic ignition
Posted on May 12, 2009
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
agent91
  • 2100 Answers
SOURCE: i have a briggs and stratton 14 hp ohv engine on
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Posted on Apr 21, 2010
  • 36 Answers
SOURCE: i have a grazer zero turn lawnmower with a 20 hp
carburator needs a good cleaning out get all the sludge out with a good quality carb cleaner take the carb apart to do a good job!
Posted on Jun 07, 2010
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
What else could be wrong with my 12.5 hp kohler engine?
Is the engine sluggish and slow to pick up when throttled up?
Jul 17, 2014 | Cub Cadet Garden
2008 Husqvarna LGT2654 Idles high and bogs with deck engaged
Hi, basically the bottom case will have to come off the motor again as your friend has failed to correctly position the governor gear against the governor arm, sorry Phil.
Jun 14, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How to adjust carburetor on a 20HP V-Twin Kohler Engine, it will not idle properly
The problem is more likely that the gas has varnished inside the carb. Mine did the same thing and I cleaned the carb and it ran great afterwards.
Now I have the carb off again because someone dumped a bag of sugar into my gas tank and it got sugar all through the system and into the carb and engine. I couldn't believe how much sugar is in there. Now I'm trying to find a diagram or schematic to show the exact set up for reinstalling the choke and throttle linkage and the spring with the throttle.
Apr 26, 2012 | Craftsman Garden
It starts pinging and dies when you engage the mower
I know you don't want to hear this, but you've got some serious problems here. The motor needs to be inspected before it puts a rod through the block.
Apr 26, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a briggs and stratton 14 hp ohv engine on my murray lawn mower it starts and runs good until i go to full throttle or engage the blades then it seems to flood out and start backfiring i can lower...
Apr 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
2 mowers 19.5 hp and 27hp kohler, both die when you let off brake
Sure sounds like an elusive safety switch to me. There's usually one on the seat, the blade control, and the brake.
Jun 04, 2009 | Garden
Mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Jun 02, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
111 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
