Question about Pool & Spa
I have an older spa builders ap,4 hottub contactor wont stay closed checked relays n reset buttons every thing works heat will not come on
  • 5 Answers
SOURCE: No Heat from Spa
Tcarrigan,
Heater contactors "buzzing": Do you mean normal buzzing or extra loud buzzing? Loud buzzing or chattering can be caused by low voltage to a contactor. If normal sounds, then probably the relays on the contactors is working, but the contacts may be stuck, or burned enough so as not to make contact. First, get a voltmeter and check for 240 volts AC at the heater contactor terminals. If the voltage is low, most likely you need to check the contactors further. Check for dirty contacts, clean if needed. If the contacts are not moving when energized, then you will probably need to replace one or both of the contactors.
Posted on Jan 18, 2009
  • 22 Answers
SOURCE: I have a Hayward 11 KW spa heater that was not
check the power to the relay and pressure switch just remember the problem lies where the power dies.
Posted on Feb 18, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: spa wont heat
Check the pump make sure that it is getting power. If there is power to the pump and nothing is working then pump is bad. Also this could be your computer board is bad, a inline fuse. or the Jandy is bad
Posted on May 20, 2009
  • 3 Answers
SOURCE: layz spa pump
same problem I had so I seperated the globe by taking out the 5 screws around the middle then removed the nut from the hole the filter sits on its a strange fitting and must have a special key but I improvised by tapping it anticlockwise using a screwdriver and rubber mallet, once open identify the heater unit (it has a single wire going into it and is fastened to a length of metal pipe) and remove it by loosening the clamps at either side and pull the heater free, once free dismantle the plastic casing on the top of the heater inside you will see the live, neutral and earth wires, you can see the live (brown) wire goes to the water flow switch then the temp switch then the heater all I did was bypass the water flow switch by disconnecting the short wire from it going to the heat sensor and replacing it with the brown wire coming from the mains and it works fine now
Posted on Aug 02, 2009
  • 366 Answers
SOURCE: my spa has stopped heating above 67 degrees. Can
it's most likely a temperature sensor, what is the readout on the top side control?
Posted on Feb 03, 2010
Spa was below temp, now it heats and won't shut off.
Is your spa overheating, heating up past 104 degrees?
If so, you have a contactor (or relay) stuck shut and the spa should go into OH at 108 degrees.
d
If your hot tub is only heating to 104 or what ever temp you have it set at and the motor runs 24 hours a day there are a couple of things you'll want to check.
First, make sure that you do not have the pump set to run 24 hours a day.
Second, you'll want to see if the pump icon is lit up on the control panel. You will want to check to see if the icon is on while the spa is supposed to be resting. During filter cycles the icon will be lit. If you are not in a filter cycle and the pump is on while the icon light is off, you have a stuck contactor (relay). The relays can be found online for less then a couple of dollars.
If you have any more questions feel free to ask.
Feb 23, 2015 | Dream Maker Spas Dream Maker Spa - X500...
My hottub wont heat. I press the heat button and the bubbles come on
Check to see if there is an open limit (high temperature) switch that can be manually reset.
Feb 08, 2015 | Pool & Spa
Spa builders ap-4 owners manual
Contact Spa Parts Shop they should be able to help.
Nov 08, 2012 | Pool & Spa
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Apr 08, 2010 | Pool & Spa
I have an older Catalina spa with acura controls. The tub will no longer heat up. The pump cycles but the heater and light does not come on
These older style controls are easily repaired but require some electrical diagnosis expertise to determine the problem.
1. Check the pressure switch to make sure it is working properly - Use a continuity checker to see if the pressure switch is closed when pump is running. If not then check for proper water flow. Dirty filter, obstruction in plumbing. If flow is good, replace the pressure switch and see if heater works.
2. Check to see if the heater has 220V at the heater terminals when heater circuit is running. If not, then check to see if the heater contactor (relay) is actuating. Check Hi-limit switch, Thermostat and pressure switch for continuity. If heater has voltage, check for current draw, using a clamp style amp meter around on of the heater wires. look for about 20 amps. If voltage is present but no current draw, the heater is bad.
3. The spa light is a completely separate circuit, check the air switch, air line, button and light bulb. Its a 12V AC circuit.
Feb 09, 2010 | RTO Pump Volute, Acura, Maverick,No IMP
Hot tub wont stay hot
Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463 http://www.maryland-hottub-pool-spa-repa... or see them on http://marylandhottubrepair.blogspot.com...
May 20, 2009 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
No Heat from Spa
Tcarrigan,
Jan 15, 2009 | Pool & Spa
Pool & Spa Logo
277 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
