Question about Dell Inspiron 6400 Notebook
Dell Dimension 8250 PC running Windows XP has CPU always at 100%
I run Windows XP on my system. I formated my HD 4 Times and reinstaled Windows XP 4 different times. My whole system runs slow. I click on a program and it takes 5 min. to boot up. I currently having 100% CPU Usage. I currently have no programs or softawre on my computer. The only things i have is the Drivers that a Dell. Tec. Support agent told me to install. I replaced the Hard Drive and i relaced the Video Card. I also replaced my Wireless PCI card. I don't want to replace the Processor or the MB yet cause that is BIG Bucks. I also Ran the 32-Bit Diognostics test from my Dimension Resource CD. It came back saying that i have no Cache.
Error Code: 0700:0120 No ache Detected. Cache might be defective or not present.
You can also e-mail me at
Please help me I live off the computer.
Thanks in advanced,
  • 1 more comment
  • Colton Gilbert Jan 03, 2009
    i don't know wha process are using it. Dell doesn't even know. I called Dell but Dell Connect couldn't connect cause i run so slow. I have 512MB of Ram. and i have 2.66 Giga Hertz. I have a 120 GB hard drive and i formatted 3 different ways different times. I formated quick once, formated non-quick once, and i FDISK once when i booted from my Dell Dimension Recource CD. I opened a DOS session and typed in FDISK and manually deleted the partition.
    how do i get to the advanced settings? from control panel or what?
  • John Hong
    John Hong May 11, 2010
    Your CPU is at 100 but what process(es) are using it.
    How much RAM do you have.
    How big is your hard drive.
    When you reinstalled, did you do a format (not quick)
  • Dell Master
  • 787 Answers
The cache is nothing more than a file on the hard drive, if it is missing Windows automatically creates it. If it was corrupt, formatting would have gotten rid of it. Try booting in safe mode (and afterwards safe mode with networking) to see if you have the same problem. This could also be a hardware issue, remove any cards that have been added (including video, I assume it has an onboard chip) and see if it helps. If any of this helps, it gives us the info to fixed it permanently.
Posted on Jan 03, 2009
  • 143 Answers
Dear sir
it's memary related problem if yr all setting is ok then just test replaced yr RAM then chek it.. and first of all try 1 thing... u have to chek CASHE memory status on yr bios whitch is in advanced settings u have to chek fisical cash and cpu cash mem is ENABLE or not.. if yr pc has inter cash mem problem u need to change yr mother board it's bad but tru otherwise try to change yr RAM then try... It's Help u...:)
please vote
  • Chinmay Joshi
    Chinmay Joshi Jan 05, 2009
    dear sir
    advance setting is in bios which is in mother bois program when system power on just press F2 or DEL then it's show a bios menu when bios menu appier there is copple of opction show u have to find advanced setting or in some ware found " INTERNEL CASH" and "CPU CASH" and make is sure both are ENABLE if both are enable then try to install windows in other partation then chek it it's help u...:)
    please vote
Hi, my pc is not working well since i installed os xp home edition, its running too slow in spite it has 512 ram and 40 hd,i havent installed the drivers i mean nothing and th cpu usage is stil 100%. what...
Windows XP needs at least 1 GB of RAM to function reasonably and for best performance, go to 2 GB. But that might not be the main problem. You really need to install the system drivers to make the O/S work with the hardware. Then run the command MSCONFIG from the command line and click the startup tab to see what might be running in the background. Uncheck the things you don't need.
Sep 10, 2010 | Dell Dimension 4600 PC Desktop
How do I restore a Dimension 8250 to original factory settings? It's running XP. Control F11, F8, and using the system restore feature does not seem to do the trick.
to restore to your pc as it was from the factory you will need the cd's that came with the computer. one of those will be the Operating System cd. Once you have located the correct cd, boot from that cd and follow the instructions to reinstall the operating system.
Aug 08, 2010 | Dell Dimension 8250 PC Desktop
When I start up my Dell Dimension 8250 (Windows
Sounds like the machine got stuck in the middle of a installation of windows. Best thing to do is to reinstall windows and let the cd format the hard drive, if it can't format the hard drive then the hard drive is bad and would need to be replaced.
Apr 23, 2010 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250 ,FAN TOO FAST & Noisy but CPU COOL...
The fan settings can be found in the BIOS. On a Dell machine, when you turn the computer on repeatedly hit F2 until you are brought to the BIOS. Search through there until you find something named Acoustics, change the option to run at a lower level. Remember to save the changes before you exit.
Jan 26, 2010 | Dell Dimension 8250 PC Desktop
Want to wipe hard drive on dell dimension 8250
You don't need a recovery cd (or any other cd) to wipe the hard drive. Boot to a command prompt and type "format c:"
Reinstalling your operating system is the only time you need a recovery cd. If you have no way to reinstall your operating system, don't wipe the hard drive.
Jun 30, 2009 | Dell Dimension 8250 PC Desktop
Full system restore without disk for dell dimension 8250
The Dimension 8250 was not equipped by Dell with an automated re-image process. If you want a clean installation of Windows, it will require a manual installation from the Dell Windows Media, followed by installing the drivers from either the resource CD or internat download. Once completed, then reinstall all applications.
Apr 12, 2009 | Dell Dimension 8250 PC Desktop
I had to erase reformat and reinstall xp on hard drive
your drivers are available here ;
download the specific drivers to your desktop (so you can find them) install in this order, chipset , sata if needed, video, audio.
make sure you check the windows updates site afterwards for all the new windows updates since your version of XP was purchased.
Apr 09, 2009 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250 won't boot-up IDE fail code 5
install your OS and then firstly run chkdsk..
Jan 21, 2009 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250 PC running Windows XP SP2 has CPU always at 100%
I guess it could be a virus, avast is not the best antivirus in my opinion, try to get a norton antivirus or NOD32 update it and run the scan, it ocuurs when a replicating virus copies files to all your HDD and is always busy...making system busy...and one more thing there could easily be a copy of the virus in your pen drive as well...
Jan 19, 2009 | Dell Dimension 8250 PC Desktop
Samsung SpinPoint SV1203N 120 GB FHD
Try increasing the actual partition to the capacity numbers in the windows xp formatting , and also format the hard drive using NTFS .
Dec 08, 2007 | Samsung SpinPoint V80 SV1203N 120 GB...
Dell Inspiron 6400 Notebook Logo
694 people viewed this question
Alun Cox
