Question about Black & Decker Mouse Sander/Polisher
Insde rubber mounts broken,where to buy replacement
The inside rubber mounts,that the srews attach to to hold the plate on,where to get replacement
  • 2,005 Answers
Black and decker service center near you will be able to help
Posted on Sep 30, 2013
Replace right rear door handle on 06 Hyundai Tucson
Is this the outside or inside door handle, the inside handles are very easy to change and should be avaiable fro a junk yard or even amazon carries some items, there normally 2 srews that hold them in, then you unhook a long thick wire attachment that goes to the latch and it comes right out
Apr 19, 2014 | 2006 Hyundai Tucson
Can i replace the rubbers inside my engine mount its the top one above the gear box on my mk4 golf 18t GTI ?
i think the rubber is vulcanized into the metal u have to buy the whole mount
Mar 11, 2014 | Cars & Trucks
While using our garbage disposal this afternoon, it went from grinding to humming. The blades do move freely, but the plate is very loose and tips. Is it possible to tighten the plate?
There is no way to tighten plate that I know of.
Maybe a clever welder could stick it back together, but the problem implies something underneath is rusted out or broken. The main thing is the cutter plate, and if disposal wobbles, it will loosen drain pipes under sink and cause dripping.
I wrote some tips for installing new disposal, and include them here since disposal will be replaced at some point.
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket.
How to replace disposal:
Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Make sure there's enough putty that it squeezes up all around sink basket.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 06, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 is about 15 years old and is leaking from the bottom -- from the reset button, the plate on the bottom, and around the electric cord. Can I fix it or does it need replacing?
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
If just the rubbers in the engine mounts are bad, could just the rubber pack be replaced ?.
You have to replace the whole mount. They aren't that expensive. I suppose you could replace just the rubber, but they don't sell them that way.
Sep 25, 2010 | 2000 Dodge Neon
How to replace broken wheel lug?
Hi
With the car on a ramp and secure - Remove brake caliper, remove brake disc and undo the hub which has the lugs sticking out.
To do this, remove the metal cap with a screwdriver. Undo top lock nut, washers, castle nut and wheel bearings. This will allow the hub to be removed.
Using a press or a hammer, pop out the broken lug. Refit a new one, this might need pressed in, or you could get lucky with a hammer. Refit all the parts, regreasing the bearings before hand.
Vote for me please for helping, thanks :)
Jun 28, 2010 | 1991 Mercury Capri
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
The passanger mirror was broken and has fallen from the car. It is still hooked up to the power moter but I will need to by and install a new mirror because the bracket is broken. Please describe how to...
REMOVE THE MIRROR TRIM PANEL.THEN UNPLUG THE ELECTRICAL CONNECTOR FROM THE POWER MIRROR SWITCH.THEN REMOVE THE 3 RETAINING NUTS AND DETACH THE MIRROR FROM THE VECHICLE.
Feb 27, 2010 | 1998 Oldsmobile Eighty Eight
Motor mounts
Most motor mounts are basically a piece of rubber attached to a piece of metal. Rubber just dries out after time and begins to crack off. Accelerating hard can speed up this process.
Aug 21, 2009 | 2004 Chrysler PT Cruiser
Need to replace the passenger side mirror,glass only. does anybody know if the plastic backing plate the mirror is attached to pops out of the holder? If it does, it would make it easier to fit the new...
Just replaced the mirror glass myself. Don't have all the answers but can tell you this much.
The passenger side mirror on my 2004 Odyssey was hit by a projectile which caromed off the upper door frame. Left standing was a functional mirror base (motor driven part which has four, short, horizontally mounted rods) still attached to the mirror shroud and a separate assembly of the mirror glass and plastic mount.
I purchased the mirror glass alone online from a Honda dealer, removed the old mirror glass from the mount, and mounted the new mirror to the mount. To do this, look at the tabs which hold the mirror to the mount, and slide the mirror across the mount in the obvious direction. It will take some force. I had the benefit of having the mount/mirror glass blown out of the mirror shroud so it wasn't too difficult. If the broken mirror is still mounted to the mount and inside the shroud, push the bottom of the mirror inward so the top edge of the mirror can clear the top of the shroud. Then pull up on the mirror glass to slide it off the mount. This will take some force but fortunately, the mirror glass is already broken so you don't have to be gentle. Wear gloves or protect you hands while doing this.
Reverse the process for install the new mirror glass.
Now for my key tip. I had to remount the plastic mount/mirror glass assembly onto the motorized mirror base. I could see that it snapped in, with proper alignment, by pushing straight in. I applied quite a bit of force and simply could not get it to snap in place. My solution, was to put the assembly in a 200F oven for 15 minutes to heat the plastic to make it more flexible. Using paper towels to handle to avoid burns, I aligned the closures with the four, small, horizontally mounted rods, and with a moderate amount of force, the assembly snapped into place.
Hope this makes sense. I believe most people will only have broken mirror glass and not have the plastic mount with mirror glass come off the motorized base as I did.
Apr 19, 2009 | 2004 Honda Odyssey
Black & Decker Mouse Sander/Polisher  Logo
149 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
