Samsung wf317aag/xaa washer I get a (be)error code
This washer is displaying a (be) error code
  • 380 Answers
SOURCE: HAVE LE CODE ON SAMSUNG WF316LAS/XAA WASHER LE CODE AND BEEPS
LE is a water level issue.
- The part of the hose where the water level sensor is
located is damaged (punctured).
- The hose is clogged with foreign material.
- The hose is folded.
- Too much lubricant has been applied to the insertion
part of the air hose.
- Hose engagement error (disengaged)
- Part fault (Faulty internal soldering)
- The water level sensor terminal is disengaged.
- Main PBA fault.
Posted on Dec 23, 2009
  • 1531 Answers
SOURCE: I have a Samsung front load washer model #
to properly install this you nee to remove the retaining spring on the front of the boot.
then remove the lid.
next remove the four screws that hold the control panel in place.
then remove the four screws that hold the fron panel in place ther may also be two screws on the bottom of the front panel.
once you remove the front panel you need to set it aside but the door lock switch is still attached so be carefull.
one you remove the front panel you can get to the other retaing spring and remove the boot.it is easier for me to also remove the counter weights on the front of the tub.to put the boot back on.i hope this helps would like to here more on your progress
Posted on Feb 02, 2010
  • 380 Answers
SOURCE: samsung washer wf218anb/xaa has code dc and wont
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Posted on Mar 10, 2010
  • 3 Answers
SOURCE: Samsung P801DWNXRC Frontload washer displays E6 error code
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
  • 5 Answers
SOURCE: I am moving across the
go online to smsung.com. you should be able to buy any parts you need through them.
Posted on Sep 26, 2010
Samsung WF317aag-xaa front loader will not drain. I have replaced the pump motor and the PCB. When I put the machine to spin the door locks and I hear two click and then nothing. display ND again.
Have you check with a multimeter to see if you have 120volts to the pump? If so you may have a clogg in the hose that goes from the tub to the pump. I've seen it before.
Jul 01, 2017 | Samsung Washing Machines
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to www.repairclinic.com and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
Samsung vrt front load washer
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
Aug 16, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Describe your samsung wf-b 1061 error code 5E Problem
Error code 5E is the code telling you that you will need to clean the filter. After you clean the filter the code will go away.
Dec 19, 2010 | Samsung WF317AAG Front Load Washer / Dryer
Samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Jun 24, 2009 | Samsung DV317AEG Electric Dryer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
