Question about Keurig Milk Frother
Keurig Milk Frother doesn't work properly
  • Decarpo junior
    Decarpo junior Nov 06, 2017
    It's not easy to make an effective and perfect cup of coffee, but if you have a right equipment then it's easy and simple, we providing you the best and high-quality milk frother at reasonable prices.http://www.milkfrotherjudge.com/
  • 1,511 Answers
Plugged ports or bad milk.
Posted on Jan 31, 2014
3 Suggested Answers
reet_peti998
SOURCE: I put milk in my Keurig and now it won't work...i think the milk burned
..wait..you mean you poured actual milk into the water reservoir on a Keurig coffeemaker..?
That's not good.
What prompted you to do that?
My advise would be to boil water in a kettle, adding about a half-cup of regular vinegar. Pour this into the coffeemaker and let it run through a cycle with just the hot water/vinegar solution. Next, run plain hot water through it.
Hopefully, this will help with flushing out any/all milk that's clogging the coffeemaker. You may have to do this several times to remove the milk residue..milk will cling. (and will start to smell foul..which may or may/not attract insects) so don't ever do that again!
Phoning Keurig Customer and product support may assist you further. They are generally very helpful with all inquiries and issues.
Keurig single-cup coffeemaker
http://www.keurig.com
(866) 901-BREW (2739)
Posted on Jul 17, 2012
Testimonial: "Thank you so much! I was trying to make hot chocolate...I'm such a dodo...I will try this."
heatman101
  • 43501 Answers
SOURCE: Our Keurig doesn't fill the cup. It generally
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 25, 2011
Hi, We have a Saeco Royal coffee machine and the milk frother doesn't seem to be working. Need some advice as to what could be the problem?
1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Dec 20, 2016 | Saeco Coffee Makers & Espresso Machines
My Keurig Milk Frother stopped working. The green light comes on but turns off immediately. Is there something I can fix?
How long have you been using that? Why not try the frother from Kitchen Ace. I can assure you that the quality of there products are really awesome!
Amazon com Kitchen Ace Can Opener Stainless Steel with Smooth Edge...
Sep 12, 2014 | Coffee Makers & Espresso Machines
The base broke looking for a replacement
Go on line to the parts dept. they have parts you need.
Mar 11, 2013 | Keurig 5074 Milk Frother
Keurig milk frother got wet now not turning on
It is burned out and won't heat. RePlace.
Nov 21, 2012 | Keurig Milk Frother
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Jan 09, 2010 | Coffee Makers & Espresso Machines
Keurig Milk Frother Logo
756 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
