I need a tire for the pts turbo 1000 and a manual
I don't know if this recumbent bike had a computer in front but it has a little pedometer like control on the left and 3 speed beer shift on right Of seat... Anyone have any idea where to find these items?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
2 Suggested Answers
  • 1030 Answers
SOURCE: My 61" RCA rear projection
When this occurs the first thing we examine at the shop is the front button curcuit board. or button assembly. Generally when those become damaged it can cause this. What is definatly a given is the processor of the tv is somehow recieving the command "put up the main menu" it recieves this command signal from ether the remote or the front panel button. Sometimes when people clean they use windex or other cleaner. sometimes this may get into those buttons and short them out. or in normal use mosture or just general use can cause this. When this occurs try pushing the menu button on the front panel... does it go away. The chances are if the buttons are damaged the board will have to be replaced. At our shop this repair will run 50 to 75
Posted on Jun 14, 2011
I need a tire for my pts turbo 1000 recumbent bike and a manual to help me work the thing.
Here is a link with info on this and the link below is supposed to be a link for a replacement wheel/tire that will work.
http://airless-tires.typepad.com/airless-tiresorg/2010/07/pts-turbo-trainer-tire-11-years-of-sales.html
The Air Free Savannah Cruiser 27 x 1 3/8 (17-18mm) Urethane Airless Bicycle tire will fit the PTS Turbo Trainer perfectly. In Eleven years, not one person has ever sent one back, nor has one person ever said they couldn't get it on. The Savannah tire was designed to fit a bicycle, but it has the right height off of the rim and it squeezes into the rim perfectly and all owners report that they are able to ride again with out any problems.
http://www.airfreetires.com/shopping/p-101-27-x-1-14-nu-teck-savannah-cruiser17-18-630.aspx
Oct 26, 2012 | Televison & Video
I have a Fitline r100 stationay bike looks almost new but we don't have a manual and it needs an adapter don't even know where it goes, I hope someone out in this big wide world can help us ou
Hi, I just had the same issue. Look at the recumbent bike from the front (facing the handlebars head-on). The plug is inset into the bike a few inches off the ground on the left side.
Apr 24, 2012 | Cycling
I own a 2007 Yamaha Virago XV250 VI. I am looking for an owners manual as I know enough about my bike to know I don't know. Currently I know that the front tire needs air but I don't know to what...
Look at the sidewall of both tires. There will be a 'MAX PSI' embossed on the tire. It will probably say Max 45 PSI. At 45psi the bike will ride like a rock. At 15psi it will ride really squirrely. Find a psi at which you feel the bike handles well and rides well. One rider may weigh 125 pounds and the next rider may weigh 300 pounds. The best psi for each rider will be different due to weight. Chances are that 30 to 35 psi will do the trick. A Yamaha dealer should be able to get you a manual. Please take a moment to rate my answer. Thanks.
Jun 06, 2011 | Yamaha Xv 250 Virago S Motorcycles
Need the replacement (tire) band for around the front wheel of the PTS Turbo 1000
Type in your browser: PTS Turbo 1000. That will show up all the available shops or internet shops where to get it.
Apr 02, 2011 | Tunturi Cycling
PTS Turbo 1000 Recumbent Exercise bike
Hey im55830,
I was the production foreman for Pro Tec way back when, so hopefully I can help you a little.
As for the tire, depending on the actual production date and model, most of them were manufactured in house, so unless someone happens to have a supply stashed somewhere there is no direct replacement.
It is possible, and some of the first ones built did, use a normal tubed bicycle tire. We switched from those because under heavy use they did wear faster than we liked. So that is one option. I understand there maybe a website that carries solid tires that will work. Another option is to attempt to make a tire. The material should be available at a home repair store, if you took the tire in and tried to match the tubing. This is a last resort in my opinion but it is feasible.
Honestly I think I would try a normal tire or solid first. You should be able to remove the wheel and take it to a bicycle shop. It will need a liner to protect the inner tube. If you need I can walk you through removing and reinstalling the wheel.
As for the computer. For the life of me I can't remember the brand we used. I am guessing you have the handlebar mounted one with a small square head, as opposed to the fully computerised 2000 model.
Replacing it may be a bit of a problem. The computer set up was a stock bicycle computer. However we made a jumper wire to accomidate the length of the frame that plugged into the sensor lead and the computer mount.
As a stock item the sensor was connected to the mount so it involved cutting the wires, soldering connectors onto both the cut end of the mount and sensor. Then making another wire with connectors to run from under the seat along the frame and to where the sensor is mounted near the wheel. In theory any new bicycle computer could be used to replace the old one.
If you aren't up for that task, there's the possibility that there is some sort of wireless system available.
To install it you would need to lossen or remove the wheel cover to mount the other half of the sensor unit to the spokes. Depending on when the bike was manufactured this can range for very easy to a bit tricky.
Probably not everything you wanted to hear but I hope it helps
Feb 03, 2010 | Cycling
Need a new monitor
This link might be helpful
http://www.pro-tec.net/
but I also found this information
http://www.nutritionalsupplements.com/supplements/viewtopic.php?t=7291
I hope this helps
Dec 29, 2008 | Exercise & Fitness
TIRE
I think you meant http://www.airfreetires.com/
Dec 23, 2008 | Cycling
PTS Turbo 1000 recumbent exercise bike
Wow, just happened to be searching around and found this on google.
Dec 04, 2008 | Cycling
Vital Fitness RB-251 Recumbent Bike Manual
Can I purchase a computer for my RB330P recumbent bike? If so where and how much?
Aug 23, 2008 | Sport & Outdoor - Others
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
