Question about MSI G41m-p34 Desktop Motherboard - Intel Chipset Micro Atx Socket T
G41m-p34 mainboard schematic - MSI G41m-p34 Desktop Motherboard - Intel Chipset Micro Atx Socket T
Hard disk gb maximum
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3505#dl
The mainboard does not have a limit for the harddrive size.
But the windows system sometimes have a limit especially windows xp.
A new sata driver or a bios upgrade is sometimes needed when you add a big harddrive.
Note: take care not to flash the bios with a wrong one if needed.
And also the new drive must be formatted ( in NTFS format ) before you can use it.
If you still run windows xp, try to make more partitions, so windows can see the new drives.
Other system like windows 7, does not have this limit.
Good luck
Jul 31, 2013 | Gigabyte GA-G41M-Combo Motherboard
Gigabyte GA-G41M-ES2H LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard
http://www.gigabyte.com/products/product-page.aspx?pid=3468#ov
A new hdmi connector, can be ordered by a gigabyte dealer.
But changing the connector, is not a do it your self job.
I suggest you to buy a graphic card, to add on the mainboard in the
1 x PCI Express x16 (orange slot) for better performance.
A new graphic card, does also have the hdmi connector
This will be the cheapest way to repair it.
Good luck
Feb 09, 2013 | Gigabyte GA-G41M-ES2H LGA 775 Intel G41...
Gigabyte ga41 combo motherboard doesn't detect my second hard disk
Hello you can download the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=3505#manual
Adobe reader is needed, to read the content.
Try to enter the bios, and look for the drive, it must be seen in here.
Do you have all the drivers installed, for the mainboard ??
The drive must also be formated, so it can be used.
Good luck
Jan 26, 2013 | Gigabyte GA-G41M-Combo Motherboard
No VGA output
Hello the drivers site is here:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=G41M-VS3
The manual:
http://www.asrock.com/mb/overview.asp?cat=Manual&Model=G41M-VS3
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Nov 28, 2012 | Asrock G41MVS3 Motherboard
Msi 760gm-p34 fx
Download drivers here:
http://www.msi.com/product/mb/760GM-P34--FX-.html#/?div=Driver&os=All
Please select your windows system.
Next the driver.
Unzip the file before you install it.
Other files can be selected in the download box.
Good luck
Nov 15, 2012 | Computers & Internet
How to connect Memory Card Reader to msi g41m-p34
If your memory card reader did not come with the Usb connector of if you don't have any, you need to buy one. It's a cable that connects your memory card reader to your computer for you to view/upload multi-media files from your memory card.
the cable looks like the one on shown here (with a card adapter)
that cable looks something like this: kyleconyo.jpg
Aug 23, 2011 | Computers & Internet
Hi. i have g41m combo i cant install windows xp...in the last 7 miniutes of instalation the pc brakes... when windows is saving files:S
Hi, you can download a manual and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=3500#dl
My guess is that the windows disc is damaged
thats why the installation stops.
Your mainboard can run windows 7.
Consider that instead of the old xp that soon expires.
Aug 23, 2011 | Gigabyte GA-G41M-Combo Motherboard
Formula
What you have posted is not a complete picture (nor statement) of the problem. The syntax I see (in briefly looking at it) appears okay.
Suggest you start with...my problem is I get the following screen (refusing to accept my input) when I try to enter....(what). Also, there are relationship tools which will show you the problem...(in RED)....just backtrack. Read the help menu for this information.
Jan 23, 2008 | Microsoft Excel for PC
MSI G41m-p34 Desktop Motherboard - Intel Chipset Micro Atx Socket T Logo
85 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
