Question about Black Bull 10 GALLON SAND BLASTER
Inconsistent sand coming from nozzle sand blaster
Volume of sand out of nozzle changes from normal to nothing within 3 to 4 seconds
Sandblasting
Suggest that you carefully drill out the nozzle to suit your new material size. sand for sand blasting has to be total dry or it will cause blockages
Jul 20, 2013 | Clarke Power Products Clarke 10 Gal....
RAV 4 - Inconsistent brake pedal pressure
Take it back to them anyway you really have nothing to loose. The may have a Techinical Service Bulletin (TSB)with regards to this problem. See what they say first if their answer is unacceptable come back and we will help you out.
Mar 14, 2010 | 2009 Toyota RAV4
Gun has very little sand coming out
The feed is plugging up either because of too large a piece of material (ie recycled sand) or moisture. Where i live, if I try to sandblast at less that 40 degrees f., even with dry sand, the temp makes my 50 foot hose cold, & sand does the same thing as your description. I also have a 80 lb unit that will do the same,
For the small ones that are not pressurized, (I have one that you just stick the end of the feed hose into the sand bag) my normal problem is if the sand is damp, since the sand is new. hope this helps, rick
Apr 04, 2009 | Jet Air Tools & Compressors
Sand Blaster: air shot out of water trap.
1. do you have an adequate air compressor, meaning can deliver sufficient air supply to the sand blaster. 2. if you have an air leak at the water trap at the bottom of the trap it self. you need a new one. 3. it is a must to have a water trap when using a sand blaster.
So what I would do is replace the water trap and install the new water trap at the compressor between the compressor and the air hose coupling. the reason for this is your less likely to have it fail at the compressor VS at the sand blaster. once you have done that. you need to make sure that you have no more than 3/4 of media / sand in the sand blaster itself.
then open air supply valve #1 where the water trap is or was a 1/4 -1/2 way. then open the mid way valve#2 1/4 - 3/4 way. and the bottom valve#3 open 1/4 - 3/4 way. getting the air supply valves all set correctly is hard to do some times.
Air valve #1 supplys the air to the blaster.( more air the better)
Air valve #2 supplys the air going into the top of the blaster tank. ( wich pressurizes the top of the tank to push the sand or media downward )
Air valve #3 supplys the air mixture to sand at the bottom of the tank.
Mar 20, 2017 | Clarke Power Products Clarke SB9008 10...
Need to find where to get info on how to sandblast
make sure first of all you have a big enough compresor to run ur sand blaster always put clean sand in it,try using a screen if u have to reuse sand if big enough chunks get in the sand it will clog up.hold away from object to be sanded about 3 inches away from area to be sanded.always keep blaster moving if u keep it in 1 spot to long u can warp the metal.other then that i dont know specifically what u need to know.
Dec 22, 2008 | Air Tools & Compressors
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Not printing in black
Turn off the Stylus CX. Load letter-size paper in the sheet feeder. Press the ink and ON buttons together and hold them down for about 3 seconds.
The Stylus CX turns on and prints a test pattern, which includes a nozzle check. If the print comes as = >
Nozzle check pattern with no gaps, and if its print in black then reinstall the printer driver
or => Nozzle check pattern with gaps and black doesn't print please send the printer for repair
Sep 19, 2007 | Epson Stylus 680 InkJet Color Printer
Black Bull 10 GALLON SAND BLASTER Logo
20 people viewed this question
Top Black Bull Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Black Bull Garden Expert? Answer questions, earn points and help others
