Question about Eclipse AVN-6620 DVD Navigation
No power on the avn6620 - Eclipse AVN-6620 DVD Navigation
Not powering up
you will probably find it's just a bad earth wire
Nov 29, 2013 | Eclipse AVN6620 Car Video Player
Need to find the harness plug for subwoofer and video
I buy a Eclipse AVN6620 radio but it missing the harness plug for subwoofer and the one for video, I want to know where I can find this plugs, please let me know if you need more information.
Jan 06, 2013 | Eclipse AVN6620 Car Video Player
I need to find out how to remove the power steering pump on a 2006 pontiac grand prix 3.8L
Power Steering Pump Replacement
Removal Procedure
1. Remove the accessory drive belt.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Remove the tire and wheel assembly.
4. Disconnect the power steering pressure hose from the power steering pump.
5. Disconnect the power steering return hose from the power steering pump.
6. Disconnect the harness connector (4) from the power steering pump (1).
7. Remove the power steering mounting bolts from the power steering pump.
8. Remove the power steering pump from the engine.
9. Remove the power steering pump pulley from the power steering pump.
10. Remove the power steering pump reservoir from the power steering pump.
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump.
2. Install the power steering pump pulley to the power steering pump.
3. Position the power steering pump to the engine.
Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts.
Tighten the bolts to 25 Nm (18 ft. lbs.).
5. Connect the power steering pressure hose to the power steering pump.
6. Connect the power steering return hose to the power steering pump.
7. Install the harness connector (1) to the power steering pump (4).
8. Install the accessory drive belt.
9. Fill the power steering system with fluid.
10. Bleed the power steering system.
11. Operate the power steering system and inspect for power steering system leaks.
*This originally came from abauto
Mar 24, 2011 | 2006 Pontiac Grand Prix
I have an eclipse avn6620 and I'm just now installing it. I turn it on and it says enter map disc-the problem is I never had a map disc or even knew of a map disc. I paid $1,100 for the unit and it didn't...
I guess u got fucked buddy.go to the store where u bought it and ask them for the cd.The radio cant,wont,and will NEVVERRR work without the cd.And them rip offs at the store should know better than that.Its like selling you a pc with no windows on it.YOU NEED THE CD TO GET IT STARTED.Then you can take ot off and use it anytime u use the gps.its the only time u'll need it :D
Jan 12, 2011 | Eclipse AVN-6620 DVD Navigation
I jus want to reset my eclipse avn6620 how do i reset it?
To reset your eclipse avn 6620, first you need to see to it that it has been charged for at least 2 hours, then you press and hold the power on/off button, holding it for at least 15 to 20 seconds should restart the gps, then it will be reseted that way.
Hope this helps.
Dec 22, 2010 | GPS
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
Check gps attenna
Try to reset your radio by romving the power completly on it. Restart it with your map dvd inside and wait for the update. When its updated , go in the gps screen. and start your car, turn around your block 3-4 time and sometime it relocate alone. ill try to check in my user manual, there is a way to tell the gps your exact location on the map , click it and make it your current posotion. Why it does that? Cause maybe your map dvd is not up to date , and your area isn't updated in your map dvd.
Jun 12, 2008 | Eclipse AVN5500 Car DVD Player
Eclipse AVN-6620 DVD Navigation Logo
Top Eclipse GPS Experts
Will Halftowaite
Are you an Eclipse GPS Expert? Answer questions, earn points and help others
