Question about Canon PowerShot S110 / IXUS v Digital Camera
White screen appears on my Powershot S110 Digital ELPH
I cannot use my Powershot S110 digital elph camera because every time I turn it on only a white screen appears.
  • Anonymous Feb 15, 2009
    mine only appears black
    Genius:
  • 2,985 Answers
This indicates a screen connector problem with the main board This is a workshop job Contact Canon Tech help line for the next move
Posted on May 17, 2007
SOURCE:
White pattern in picture
Can you post one of these pictures here?
Oct 17, 2007 | Cameras
What are the optimal settings for my digital camera? I have a brand new Canon PowerShot 12.1-Megapixel Digital ELPH camera, but I've been really disappointed in the quality of pictures it takes. For...
Small white circles usually means dust on the lens.  Remove the dust with a blowerbrush - not a tissue.
You are asking for a "1 size fits all" solution for your settings, and indoor and outdoor use really means different settings.  What you should be looking for is the "White Balance" setting - on Auto it will be about right, most of the time.  You should be able to switch between indoor/outdoor settings (but they may be called portrait and landscape, or similar) and you will have to look through the menus for this.
Mar 02, 2010 | Canon PowerShot 12.1-Megapixel Digital...
Display screen reads "card locked" on my powershot sd700
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck.
Jul 01, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Canon Power Shot SD 400 Digital Elph - image not on screen
On most canon elph cameras you can either go through the menu and reset back to factory default and this might solve the black or white screen. If that does not work you should be able to hold the menu button down for several seconds until a reset prompt pops up. You will then click on yes for reset and this should completely reset the camera and the screen should be back to normal.
Jun 10, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
LCD Screen
Hi
Your LCD screen is either defective and needs to be replaced, or the cable has come unplugged and needs to be reset, or there is corrosion to the connector on the cable.
You can get a replacement screen easily, and you can also have it installed for you for a reasonable price. (Google Darntoothysam, we are an affordable digital camera repair business!)
Most of the time replacing the LCD will solve the white screen problem and it's really not too hard to do yourself.
Good luck from Darntoothysam com
Thomas
Jul 24, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Question
press the middle boton on canon put manaul on the camera then go down to put it in black and white
Jul 06, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon digital elph SD500 5.0
Hey i found this site that is great on how to change a LCD for the camera
http://digitalcamerarepair.googlepages.com
Nov 24, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
No picture
In the first half of October, 2005, a number of digital camera and camcorder manufacturers issued service advisories involving a range of digital camera models (as well as some digital camcorders and PDAs that incorporate image sensors). In each case, the story was similar - CCD (image sensor) failures, particularly in conditions of high heat and humidity, led to cameras capturing images with either no picture at all, or with extreme distortion and severe purple or green color casts. An example of the latter symptom, courtesy of the Konica Minolta Europe website, can be seen further down this page. We first started hearing about this problem in late September and early October, 2005, with a significant increase in reader emails about it in the first week of October. The problem understandably caused considerable concern among our readers, with many wondering whether this was an ongoing problem that could affect current cameras. Initial service advisories by Sony, Canon, Fujifilm and Konica Minolta were soon followed by announcements by Nikon, Ricoh, and Olympus. Affected cameras were all manufactured between 2002 and 2004, the underlying problems have apparently been found and corrected, so no cameras currently on the market are affected. (We are assured by sources that new cameras purchased today will not be affected by this problem. See the "What caused this problem" section at the bottom of this document, for a more detailed discussion of possible causes.) We here at Imaging Resource did a little digging into the problem, and it appears that the problems trace to certain models of image sensor chips manufactured by Sony between 2002 and 2004. (Fujifilm has stated that they manufacture their own CCD chips, so it's not clear whether or not the problems with their cameras are in fact related to those of the other makers.) The problem can take any of several forms, but all involve severe color shifts and/or severe distortions of the image. The images below show two examples (courtesy of Konica Minolta) of what the problem might look like, if your camera falls prey to it. In the early stages of the problem, the camera may still capture recognizable images, but with a washed-out appearance and a strong magenta or green tint What products may be affected? Quite a number of products may develop this problem, including digital cameras, camcorders, and even PDAs (Personal Digital Assistants) that incorporate an image sensor. The following is a list of affected models by various manufacturers that we are presently aware of. We will update this list as new information becomes available. We recommend that you check the site regularly for this and other breaking news. Here are lists of the affected products, grouped by manufacturer: Canon Digital Cameras Camcorders PowerShot A60 PowerShot A70 PowerShot A75 PowerShot A300 PowerShot A310 PowerShot S230 Digital ELPH / Digital IXUS V3 / IXY D320 PowerShot SD100 Digital ELPH / Digital IXUS II / IXY Digital 30 PowerShot SD110 Digital ELPH / Digital IXUS IIs / IXY Digital 30a Additional digital cameras added in the fall of 2006 to the original service advisory by Canon include the following, all of which went on sale starting from 2002 to 2004, depending on the specific model: PowerShot A40 PowerShot A80 PowerShot A85 PowerShot A95 PowerShot S1 IS PowerShot S60 PowerShot S200 DIGITAL ELPH / DIGITAL IXUS V2 / IXY DIGITAL 200a PowerShot S330 DIGITAL ELPH / DIGITAL IXUS 330 / IXY DIGITAL 300a PowerShot S400 DIGITAL ELPH / DIGITAL IXUS 400 / IXY DIGITAL 400 PowerShot S410 DIGITAL ELPH / DIGITAL IXUS 430 / IXY DIGITAL 450 PowerShot S500 DIGITAL ELPH / DIGITAL IXUS 500 / IXY DIGITAL 500 (including White Limited version) MV600i MV630i MV650i MV700i MV730i MV750i MV5i MV5i MC MV6i MC ZR60 ZR65 MC ZR70 MC ZR80 ZR85 ZR90 Elura 40 MC Elura 50 According to the updated advisory, available on the company's US website (as well as other regional Canon websites), the additional eleven digital camera models shown above in red may now be eligible for free service regardless of warranty status, should any malfunction be caused by the CCD sensor. For repair instructions, visit the Canon USA support website. To read the specific service advisory for your model, use the pulldown menus to browse for your specific model, or simply type the model number into the box provided at the bottom of the page and click the "Search" button. The Canon support website holds no forms or other needed documents, so you can save yourself some time (if you live in the US or Puerto Rico) by just calling the Canon Customer Support line at 1-800-828-4040. Support hours are Monday-Friday 8am to 12 midnight, and Saturday from 10am-8pm. (All times EST.) Alternately, you can send email to: carecenter@cits.canon.com.
Mar 19, 2007 | Canon ZR80 Mini DV Digital Camcorder
Canon PowerShot S110 / IXUS v Digital Camera Logo
235 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
