Question about Champion 9500 Watt Gas Portable Gasoline Generator Carb Electric Start
I need the electrical wiring diagram for champion generator c42412
I need the wire diagram for Katolight D350FRV4 432 kVA Gen
Have you tried google as there are lots of manuals available online if you search for them
Jan 07, 2018 | Electrical Supplies
Im looking for a 1976 dodge champion motorhome chasis wiring diagram
Champion built motorhomes from the early 1970s until the mid-1980s. While Dodge powertrains supplied the momentum for Champion Class A motorhomes through the 1970s, the Class C between 16 and 22 feet were powered on General Motors chassis frames. 1986 was the final year of Champion motorhome production.
It will be nearly impossible to find a chassis wiring diagram for a vintage orphan RV. Perhaps an online enthusiast forum or keep an eye on eBay.
Oct 30, 2014 | RVs
My champion generator model #46596 will run but won't give electric
All breakers OK? Then it could be lost exciter current. Her's how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With the generator running, insert bare wire ends into the AC outlet - one wire to Hot, the other to Neutral. Insert and remove quickly - there should be a flash and power will be restored. If not, repeat until you get that flash. If you are too slow to remove the wires from the outlet after current is restore, the light gauge wire should burn out before the battery suffers damage. Be quick - be careful.
Apr 04, 2014 | Electrical Supplies
Hobart welder generator
Sorry we do not have those diagrams.
Oct 31, 2017 | Electrical Supplies
How to remove and replace the stator from a champion generator
You don't state what model you have. I just replaced the rotor on a Champion Model 41302 but removing the stator is the same process.
You will need to remove the muffler and muffler outer protection. Remove the bolts that hold the muffler outer protection. Remove the two bolts that hold muffler to the engine exhaust.
Take a block of wood and place it under the engine to support the generator. The supports on the generator head end will be removed so the generator will tip down and make it difficult to remove the stator.
Remove the generator end cover by removing two bolts.
Remove the two bolts that hold the muffler to the end cover.0834b898-460f-41f6-b0a0-6704ae605277.jpg
Remove the bolt that holds the ground from the generator to the frame.
Remove the two bolts that hold the end cover supports to the rubber supports to the frame.
Disconnect the quick connect electrical connectors and remove the 120/240 volt wiring from the terminal block. See second picture below.
Remove the ground from generator to wiring cable assembly by removing the bolt that connects it to the end cover. Yellow and green wire in picture above.
Remove the bolt from DC brush assembly and pull out of generator. Picture below shows assembly removed.
The stator and cover now can be removed from the generator. Take a rubber mallet to tap on the back of the brackets on the end cover to loosen it. The rotor bearing is seated in the end cover making it hard to remove by pulling by hand. Once lose pull straight out.
The stator can now be removed from the generator end by taking the four bolts out.
The installation process is the reverse.
Nov 27, 2013 | Electrical Supplies
Electrical diagram for 8000lb champion winch
Winches are out in the worst weather so before I looked at a wiring diagram I would be checking the condition of all the terminals for clean and tight. Next check the charge rate and condition of the battery driving the winch even having a load test done on that battery to see if all the cells are ok as when the solenoid clicks but no more the results are the same as a bad battery in the car.
Jul 22, 2013 | Champion International Champion 8000lb...
I have a champion generater model# C42412 and I don't think it's working proper
what makes you say it's not working proper? Need more info...
Jan 11, 2012 | Saws
I need the wiring diagram for the model 40026 generator
Go here:
Champion Power Generators : http://www.cpeauto.com/techbulletin.php
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 08, 2009 | Electrical Supplies
Electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Champion 9500 Watt Gas Portable Gasoline Generator Carb Electric Start Logo
195 people viewed this question
Top Champion Televison & Video Experts
bobalix
Joseph Hoffmann
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
